  New Posts New Posts RSS Feed - 85 gt with 5 speed from 86
dbuck8420 View Drop Down
Post Options Post Options   Quote dbuck8420 Quote  Post ReplyReply Direct Link To This Post Topic: 85 gt with 5 speed from 86
    Posted: 15 July 2013 at 3:06pm
i have an 85 gt came with a 4 speed muncie. i put a 5 speed
getrag from an 86 gt, and i am having an issue setting up
the new cables. i did get new cables for the 5 speed, a 5
speed shifter and the brackets for the cables. i am hoping
someone can help me figure out what i am not seeing or
doing right.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 3:19pm
This may be an obvious question, but the shifter cables you got were for a 5-spd getrag tranny, right?
Cables for a 5-spd Isuzu won't work and neither I suspect would cables for a 4-spd getrag.
Post Options Post Options   Quote dbuck8420 Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 3:49pm
Not as obvious as you would think, I started off with Isuzu cables and brackets before I did research and realized what I had and that they wouldn't work. I started off with a pile of parts, including the Isuzu cables and brackets. I did order the getrag cables from the Fiero store. And got the brackets from the Fiero factory.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 4:07pm
I swapped a 5-spd Isuzu into my '84, but I have no experience with 5-spd getrags.
Someone else may be able to better advise you, but you're going to have to at least describe what the issue is that you're having a problem with.
Post Options Post Options   Quote dbuck8420 Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 4:21pm
I can't figure out how the select cable bracket mounts to the transmission
Erwin View Drop Down
Post Options Post Options   Quote Erwin Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 5:04pm
I can take a picture of my 87 GT if you want - will that
help?
Post Options Post Options   Quote dbuck8420 Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2013 at 5:14pm
Yeah that would be great.
Post Options Post Options   Quote dbuck8420 Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2013 at 10:48am
just realized Saturday night that I had been lied to
about the transmission i had put into my fiero. it is a 5
speed, but it is not the Getrag i was made to believe it
was. it is actually the Isuzu 5 speed. i really wish i
had seen this forum a long time ago,
http://www.fiero.nl/forum/Forum2/HTML/063783.html
there are pictures of all 3 transmissions put in the
fieros. so if anyone out there is looking for an Isuzu
trans. let me know, i have 1 laying around that i dont
want. i went and found a getrag 2 hours away, so i
wouldn't have to start over with getting all the brackets
and cables for the isuzu trans.
