  New Posts New Posts RSS Feed - 86 SE 3.1L Build
86 SE 3.1L Build
Lucid245 View Drop Down
Post Options Post Options   Quote Lucid245 Quote  Post ReplyReply Direct Link To This Post Topic: 86 SE 3.1L Build
    Posted: 23 May 2013 at 2:05am
Body and engine have 153K original KM's. Interior still
needs new seats, or the current set re upholstered. 86 GT
Parts Body and Shell for GT Clip Swap that just needs to
be painted.
2.8V6 Effectively a 3.1L
Automatic
Engine Rebuilt from Block Up less than 10,000K ago
Heads were replaced with 3.1L Heads, and cylinders were
bored at the same time.
New Rings, 3.1L Aluminum Valves Head Matched, Seals.
Head Gasket, Rear Main etc.
Larger Injectors Swapped From 3.1L
Accel Coil
Comp Cam
K&N Cold Air Setup
MSD Ignition Setup
Magnaflow Exhaust
Converted Hub Assemblies
Engine Mounts
New Battery
New Rotors & Brakes (extra set of calipers to rebuild
included) 2 New Rear.
Adjustable Coil-Overs, Lowered 2"
Uniroyal Tiger Paw GTS / Stock Rims, Good Tread.
Call, Text or Email for Pics
250-510-8884
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2013 at 4:53pm
Just to clarify as no one has asked yet, which crank did you use.
bcampbell View Drop Down
Post Options Post Options   Quote bcampbell Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2013 at 12:55am
Does this have aluminum heads? If not, the 3.1 iron heads
should be exactly the same as the 2.8 heads, unless they
were ported also.
'89 Firebird 3500T, T56
