87 GT Ecotec |
Post Reply | Page <12 |
Patrick
Post Options Quote Reply Posted: 03 December 2010 at 5:20pm |
Dang it. Did the engine seem okay when it was running? No apparent damage (knocking, smoking) due to it being "seized"?
Post Options Quote Reply Posted: 03 December 2010 at 5:43pm |
You need to do a oil and filter change right away. Then run it for a good 20 minutes and do a compression check on all cylinders.
This will give you a good idea of what shape it's in. The Dawg |
Medic
Senior Member Joined: 31 October 2010 Location: Canada Status: Offline Points: 121 |
Post Options Quote Reply Posted: 03 December 2010 at 9:56pm |
No obvious issues,in fact the engine was very quiet. A little white'ish smoke for the first few minutes but it cleared up. There was a water leak that started up front somewhere around the rad. It will have to be addressed.
power steering was not working either. The car was actually out of gas, I found that out when I tried to drain it and nothing came out. Put a little fresh gas in and a little ether down the intake and it fired up with out much problem. |
88 GT Northstar 6 Spd
Patrick
Post Options Quote Reply Posted: 03 December 2010 at 10:07pm |
Great. It'll be interesting to see this GT actually running around with this particular engine in it.
Romeo
Post Options Quote Reply Posted: 05 December 2010 at 9:54pm |
Oh thank goodness! I'm glad the ecotec perservered, it's a uniquity in the club, and quick as hell to boot.
bill
Member Joined: 12 February 2007 Status: Offline Points: 57 |
Post Options Quote Reply Posted: 11 February 2011 at 8:46am |
Just came across this thread. Is that the 2.4 LE5 motor, or.....? Although they cost a few bucks there is a well travelled raod to more power using supercharging for them. I also want to see someone stick an LNF turbo motor in there. 300 whp is easy with nothing more than tuning.
1988 3.2 turbo Fiero
1957 3.4 in Jamaican MG 2009 2.0 Pontiac GXP coupe |
Romeo
Post Options Quote Reply Posted: 11 February 2011 at 2:13pm |
Better yet, an LNF turbo and the Eaton supercharger. Twin-charging, it's the future. |
bill
Post Options Quote Reply Posted: 11 February 2011 at 3:25pm |
No, not in this case. The supercharger would be superfluous and a wasted expense. The turbo is sized to make power from 2000 rpm and is capable up to around the 400 BHP level, after which a larger turbo is used, but still no supercharger needed - you'll hit fuel limitations inherent in the DI injector availability before you could fit a turbo large enough to leave a hole down at the bottom that you'd want a supercharger to fill. |
Romeo
Post Options Quote Reply Posted: 11 February 2011 at 4:22pm |
Yeah, but a turbo doesn't whine. Or look nearly as cool. Or whine.
bill
Post Options Quote Reply Posted: 11 February 2011 at 4:45pm |
Let me guess - you'd be one of those knobs that installs bigger BOVs just so you can listen to them pop? How lame. It isn't about what the car sounds like, it is about performance! If not, maybe you could be one of these guys......
Romeo
Post Options Quote Reply Posted: 11 February 2011 at 5:02pm |
Medic
Post Options Quote Reply Posted: 12 February 2011 at 8:35pm |
It's a 2.2.
I have a S/C for it as well from the 2.0 Cobalt. At the moment I can't get it to start after putting in the new clutch. Ran fine before, not sure what the problem is at the moment. Must be a wire connection. |
Romeo
Post Options Quote Reply Posted: 12 February 2011 at 9:17pm |
If it doesn't even try to turn over, I'd recommend checking the clutch-depressed lockout switch. |
Medic
Post Options Quote Reply Posted: 13 February 2011 at 6:59am |
It turns over but does not start. I hard wired the depressed switch. It doesn't even try to fire, just spins. Odd since it fired up right away before I did the clutch. It must be a wire or other issue. So far everything looks to be in the right place and hooked up. A little confused about it at the moment.
Nexus
Senior Member Joined: 06 January 2011 Location: Canada Status: Offline Points: 111 |
Post Options Quote Reply Posted: 13 February 2011 at 7:53am |
is your fuel pump working/plugged in I had this problem when I pulled the batterie out of my car, the fuel pump wire is close and was pulled apart slightly not allowing it to run!!
Charlie
84 SE |
Romeo
Post Options Quote Reply Posted: 13 February 2011 at 11:14am |
Well bud, you want me to stop in? We know it has to be fuel, air or fire if it's turning over like that.
Post Options Quote Reply Posted: 13 February 2011 at 1:12pm |
Dumb question, but Steve does the car still have 2 ignition locks, is the 2nd key on and in the run position. Did the wiring to the 2nd lock get tugged?
Medic
Post Options Quote Reply Posted: 14 February 2011 at 7:12am |
Yep, checked that as well and found the rats nest of wiring tucked under the console. Problem is I don't have a wiring diagram for the Sunfire harness but the key seemed fine. It may have been tugged when the console was removed but looks intact.
Romeo
Post Options Quote Reply Posted: 14 February 2011 at 7:53am |
Oh boy. Have you got a scan tool to use? Or is this going to be a wire-by-wire continuity check?
Medic
Post Options Quote Reply Posted: 14 February 2011 at 8:02am |
Hmmm....I had/have a code reader for my S10. Scan tool nope.
