engine problem plz help me |
Guests
Guest |
Topic: engine problem plz help me Posted: 01 May 2007 at 7:49pm |
hey guys my cuzins havin a problem with his engine it seems to be runnin very slugesh almost lik its lackin power or not sukin enough air and it its also spittin black stuff or and dust out the tail pipes and then idle drops low and goes up sometimes and the car tunrs off randomly. plz help
Post Options Quote Reply Posted: 01 May 2007 at 10:29pm |
First question, what motor is it? Heck is it even a Fiero? Your not goign to get much help without asking questions with at least some details.
Be like me saying what colour is my hair? Without you ever seeing what I look like. |
Guests
Guest |
Post Options Quote Reply Posted: 01 May 2007 at 10:30pm |
its a 1987 pontiac fiero gt fastback , v6 2.8L
Post Options Quote Reply Posted: 01 May 2007 at 10:37pm |
Well spitting black from a 2.8 is an over fuel issue. First thing to check is coil and a tune up.
Next up is check for a bad O2 sensor, the best way to do that is to check with a scan tool. However you are over there and I am over here, so I can't help with my scan tool.
I would give the car a good tune up and see if that helps.
The O2 sensor controls how much fuel and the Coil, Pickup Coil, Ignition Module control the spark. |
Dr.Fiero
Post Options Quote Reply Posted: 02 May 2007 at 6:25am |
Replace the air filter.
Post Options Quote Reply Posted: 25 May 2007 at 6:36pm |
So were you ever able to fix it.
