  New Posts New Posts RSS Feed - Fel-Pro gasket numbers
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Topic: Fel-Pro gasket numbers
    Posted: 03 June 2009 at 5:54pm
Part TypePart NumberCommentQty
Exhaust Pipe Flange Gasket60650Pipe to manifold1
Intake Manifold Gasket Set - Fel-ProMS 93020Valve cover gskts. not incl.; Upper set incl.1
Auto Trans Extension Housing Repair Sleeve99139GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Input Shaft Repair Sleeve99139GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Manual Shaft Seal8792SGMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Oil Pan GasketTOS 18656(16-bolt holes); GMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Output Shaft Repair Sleeve99139GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Output Shaft Seal3543GMC THM125C 3 Spd. Automatic Transaxle2
Auto Trans Shift Shaft Seal8792SGMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Torque Converter Seal4072NGMC THM125C 3 Spd. Automatic Transaxle1
Auto Trans Valve Body GasketTOS 18661(11-bolt holes); GMC THM125C 3 Spd. Automatic Transaxle1
Conversion Gasket Set - Fel-ProCS 8699-1Oil pan gskt. for Goodwrench® replacement eng. not incl.1
Crankshaft Repair Sleeve Tool - Fel-Pro16304Crankshaft1
Dowel Pin (Cylinder Head) - Fel-ProES 74013Cylinder Head; Cyl. head alignment2
Drain Plug Gasket - Fel-Pro70822 1
Exhaust Manifold Gasket Set - Fel-ProMS 93045 1
Head Gasket Bulk - Fel-Pro512 SDHead bolts not incl.; Head bolt replacement recommended; PermaTorque Severe Duty™; 2 Req'd.2
8699 PT-2Head bolts not incl.; Head bolt replacement recommended; PermaTorque®; 2 Req'd.2
P512PERHead Gasket Bulk; Head bolts not incl.; PermaTorque Severe Duty™; 2 Req'd.2
Head Gasket Set - Fel-ProHS 8699 PT-5Head bolts & exh. pipe packing not incl.; Head bolt replacement recommended; PermaDry® molded rubber valve cover gskts. incl.; Premium valve stem seals incl.1
Head Gasket Spacer Shim - Fel-Pro8699 SP-1HeadSaver®; 2 Req'd.2
Oil Filter Gasket - Fel-Pro70672 1
Oil Pan Gasket Set - Fel-ProOS 30512 CExc. Goodwrench® replacement eng.; Cork1
OS 34501 RGoodwrench® replacement eng.; PermaDry® molded rubber gskt. incl.1
Rear Main Seal Set - Fel-ProBS 40625Rear Main Seal Set; 11.0mm thick; PTFE Rubber; One-piece1
BS 40464Rear Main Seal Set; 11.0mm thick; Rubber; One-piece; Improved design1
Main Bearing Repair Sleeve - Fel-Pro16257Crankshaft; Use w/installation tool1
Timing Cover Repair Sleeve - Fel-Pro16212Timing Cover; 1.040" sleeve length; Use w/installation tool1
Timing Cover Repair Sleeve Tool - Fel-Pro16312Timing Cover1
Timing Cover Gasket Set - Fel-ProTCS 45467Timing Cover Set w/Sleeve; w/Sleeve 'N' Seal®; 1.040" sleeve length1
TCS 45466w/o Sleeve 'N' Seal®1
Timing Cover Seal - Fel-Pro9845 1
Valve Cover Gasket Set - Fel-ProVS 50077 RServices both covers; PermaDry® molded rubber gskts. incl.1
Valve Stem Seal Set - Fel-ProSS 72530Premium valve stem seals incl.1
Water Pump Mounting Set35220 1
Camshaft Repair Sleeve - National99176 1
Crankshaft Repair Sleeve - National99298Rear; 2nd Design1
Crankshaft Seal - National5210Rear; Radial; 1st Design1
4307VRear; Viton®; 2nd Design1
Repair Sleeve - Fel-Pro99176 1
Timing Cover Harmonic Balancer Sleeve - National88176 1
5000Kit1
Timing Cover Repair Sleeve - National99176 1
Timing Cover Seal - National9845 1
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2009 at 5:55pm
After about 100 click throughs...  I finally found this list.  This is for an '85 V6.  If you click a part number, you should get a window with a picture, etc.
edit: oops.  no popup.  Guess that only worked from there site.
