fiero idle |
Guests ![]() Guest ![]() |
![]() ![]() ![]() ![]() Posted: 02 August 2007 at 6:55pm |
hey i have a quesiton ...wen i start up my fiero at times it revs so low liek tis about to stall but it jus rises bak up what do u think is wrong?
IAC could be sticky, vac leak - could be many things.
Is it only when cold? Only hot? All the time? |
ummm both ? only sumtimes though
I'd start with your IAC then.
88FieroGT ![]() Member ![]() ![]() Joined: 24 March 2007 Location: Canada Status: Offline Points: 78 |
Mine does that too. It starts like normal then dropps down to 500 rpm then back to normal then idles normally. It only does this occasionally and only at the first start up of the day.
so did u fix that problem 88fier0gt?
No but it is not doing it now. It only does it between august to october.
Because it is not doing it now, I wouldnt know if I had fixed it or not. Sorry. Have you fixed yours? Edited by 88FieroGT |
Loops87GT ![]() Member ![]() ![]() Joined: 10 April 2008 Location: Canada Status: Offline Points: 24 |
this sounds like it happens to alot of fiero owners. seems like theres a post about it every other day on PFF
