Fiero spitting out COOLANT |
Post Reply | Page <12 |
Author | ||
InfernoFiero
Senior Member Joined: 25 June 2011 Location: Canada Status: Offline Points: 133 |
Post Options Quote Reply Posted: 08 July 2011 at 9:51pm | |
I found the thermostat. I didn't know this was in the
back... I think I know where the thermostat cap is too now... but I don't where the radiator opening IN the back is. I don't have a Fiero Manual, and I know I couldn't hold out without one for so long. My apologies, hopefully I will find a manual soon! |
Patrick
Post Options Quote Reply Posted: 08 July 2011 at 10:09pm | |
As I said in my PM response to you, go to the Paper Based Archives, specifically Here and you should find all the info you need.
InfernoFiero
Post Options Quote Reply Posted: 31 July 2011 at 7:53pm | |
Hello,
This post is from a while ago, but I did manage to hopefully burp the coolant system. My car overheated again though today while I was doing some driving, I always check my temp gauge, and it slowly creeped above 220, and I managed to pull over at around 230 to see if the fan is running, and to my surprise IT wasn't. The temp was going higher and higher and nothing happened with the fan. Does this narrow down to the fact that my fan sensor is broken, and I can get a replacement sensor from the Rodney Dickmans store to fix this once and for all? |
Patrick
Post Options Quote Reply Posted: 31 July 2011 at 8:02pm | |
Works for me.
This is based on the assumption (rightly or wrongly) that there is nothing else wrong with your Fiero.
Post Options Quote Reply Posted: 31 July 2011 at 9:21pm | |
Make sure the fan itself is ok before buying the fan switch. One way to do this is by taking the plug off the switch and shorting the contact to ground (engine). If you do that, the fan should turn on. Ignition switch has to be on.
Dawg |
Patrick
Post Options Quote Reply Posted: 31 July 2011 at 10:56pm | |
Damien, I believe he said the fan works, but I'm not 100% sure!
InfernoFiero
Post Options Quote Reply Posted: 01 August 2011 at 2:19am | |
My fan works when I put the a/c on to full blast, is
that a good indication in itself? |
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 9:37am | |
I don't believe "full blast" is necessary. So I'm curious... when your Fiero appears to be overheating, why don't you activate the rad fan by turning on the a/c then? That's not the solution to your engine cooling issues, but it should at least prevent coolant from puking out of the reservoir (unless there are additional problems).
As long as you're moving forward, no fan is required to maintain proper coolant temperatures. You still have the air deflector under the front of your Fiero, don't you? If your Fiero is actually overheating (and it's not just a faulty gauge/sender), then either you haven't burped the cooling system properly, your water pump is faulty (loose impeller), or there's a restriction to the coolant flow (crushed pipes, plugged rad), etc. One of our club members (who shall remain nameless) used to have a problem with his Fiero overheating worse when his fan came on, and only while he was driving. It would cool down fine when he stopped. Turns out he had wired the fan in backwards and the fan was trying to push air forward through the rad the same time as air was naturally trying to flow back through the rad. The end result was that there was no air flow through the rad (when the fan was running while the car was moving). Took him awhile to figure out the problem! True story.
InfernoFiero
Post Options Quote Reply Posted: 01 August 2011 at 12:33pm | |
My car was overheating shortly after exiting lions gate
bridge and while being stuck in downtown traffic (stop and little go). I think it was the lack of movement that lead to my car overheating. I just found more info on this air deflector, and I'll check if my car has that though. I'll burp the coolant system one more time too. So as long as any Fiero is moving forward the fan doesn't come on as there is no need, or are you just theorizing that the fan is simply not needed when going forward? |
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 12:37pm | |
It's not just a "theory".
InfernoFiero
Post Options Quote Reply Posted: 01 August 2011 at 4:13pm | |
On a seperate note, I can't open my thermostat cap. I am
trying very hard and it just won't budge. Any special tricks? |
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 6:16pm | |
How'd you get it off when you burped the coolant system?
InfernoFiero
Post Options Quote Reply Posted: 01 August 2011 at 6:22pm | |
I opened it without any hassle the first time, just simply
screwing it off! |
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 6:26pm | |
Well, it's not corroded on then. Just use something like a wet rag to give your hands a bit more grip. You could also use a large pipe wrench, but you gotta be careful. You don't want to deform the cap or especially the neck.
Post Options Quote Reply Posted: 01 August 2011 at 9:03pm | |
Ummm, they don't just screw off. You have to push fairly hard while turning till you get the lid past the locking tabs.
The Dawg |
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 9:14pm | |
Do you actually push your thermostat cap down while turning? I never have. I'm aware of the locking tabs you're referring to, but I find if I just turn the cap without cocking it off to one side or another that it'll "click" past the tabs and continue to turn to come off. Having said that, yes, I do push down on a rad cap when turning to remove it.
Patrick
Post Options Quote Reply Posted: 01 August 2011 at 11:13pm | |
It just dawned on me that perhaps the first time you took off the thermostat cap that possibly it wasn't turned all the way on and therefore had not clicked past the tabs that Damien (Dawg) was referring to. If that's the case, and if you twisted it all the way on when you replaced it, that might explain why it seems more difficult this time around to remove.
InfernoFiero
Post Options Quote Reply Posted: 06 August 2011 at 3:15pm | |
I believe I have burped the coolant system.
After repeating step 4 and 5 twice, I turn on the engine for 30 seconds, and see that the coolant has gone down just a tiny bit in the thermostat opening... Should I assume that I have removed almost most of the air out of the system because in the burping instructions it mentions that after briefly turning on the car that I should top up the thermostat opening. |
