  New Posts New Posts RSS Feed - fiero tune up
fiero tune up
Guests View Drop Down
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: fiero tune up
    Posted: 05 June 2007 at 12:45am
n e one have an idea of how much a  full tune-up would cost for a 1986 pontiac fiero gt.... i think its in need of service also need to know wat exactly i should just get done to get it serviced properly for a good low rate or jus stuff i shoudl be doin my self thnks
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 5:55am
Plugs NGK V-Groove UR5 $15
MSD Wires $100 or cheap ones $50
Cap and Rotor $20 make sure they have BRass contacts
O2 sensor, if you don't know when it was changed last replace it $100
Oil and Filter $30 Castrol GTX 10w30 or 20w50 for high milage motors.
Thats the basics.
Post Options Post Options   Quote beken Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 11:01am
If you take it to an aircare certified shop and the O2 sensor is good, the a general tune-up is about $200 nowadays.  The includes 6 plugs, oil and filter and cap and rotor, if required.
The last O2 sensor I bought was $70.  You should also consider changing the gas filter, which is not usually included in tune-ups anymore.  But then my original gas filter that came with my car lasted 10 years before I replaced it.  The filter outlasted the fuel pump but may have been the cause of the pump going.
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 3:46pm
o alright thnks guys
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2007 at 12:10am
its been a while since i got it serviced last time was about wen i started this topic do i only need a oil change cuz i did all of the above listed... or is ther en e thin else?
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2008 at 12:55am
hey captain. the stuff u listed above? how often should the plugs and wires be changed? and how about the cap. rotor. ignition coil often shudl that be changed?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2008 at 4:10pm
Cap and rotor should be changed around 15,000 miles, wires every 30,00 miles, coil, every 50,000 miles or when it goes bad, plugs every 6-10,000 miles. Or every weekend if you are running nitrous. :)
Matt View Drop Down
Post Options Post Options   Quote Matt Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2008 at 9:52pm
Heh, show off. You're so proud of yourself aren't you?
I wanna go fast.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2008 at 10:24pm
   Na I have not ran nitrous on any of my motors in a fair while. Just saying with the "NOS" generation of new comers, if you do run a small bottle shot on your car, you are gonna need to change plugs very often.
