  New Posts New Posts RSS Feed - Leaking Caliper
Leaking Caliper
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Topic: Leaking Caliper
    Posted: 08 September 2011 at 9:15pm
Well, I am glad we didn't loose our brakes last Sunday Allan...I was changing tires and noticed on the front right side the wheel splattered with fluid...
The bleeder valve is tight and the brake line was dry...but it was coming from this area, top of caliper.  Inside where the piston is was dry...I can take pics tomorrow and post.
Question, how can I test and trace where the leak is coming from?, clean the area all up, run the car and pump on the brakes?
Thanks for the help all
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2011 at 10:57pm
If that much brake fluid is missing, your master cylinder reservoir will be low.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2011 at 7:12am
It dropped but not much...pedal is softer for sure...I want to look at it tonight, what are you up to?:)...
AllanJ View Drop Down
Post Options Post Options   Quote AllanJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2011 at 10:47pm
That sucks, Brian.  Hopefully you find the leak pronto and it's something simple.
Fingers crossed!
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2011 at 10:54pm
Just got back from what I was up to...:)
Tomorrow (Sat) I'm working on my trailer so should be home most of the day.  Come on over and we'll have a quick look.
ps.  My jack is at the storage so bring yours and if you do pop over bring my code reader, I need it.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2011 at 8:43am
Was a simple fix...tightened the bleeder valve...lol
I am out all day today, it's mow 8:40am, I can drop off the scanner on my way to the Lion's game, will call ya or call me:)
Post Options Post Options   Quote AllanJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2011 at 8:57am
Excellent news!
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2011 at 9:11am
Ya:)...
