Road trip 2009 |
Topic: Road trip 2009 Posted: 20 March 2009 at 6:32am |
So we made our first trip to Harbor Freight yesterday and GI Joes. Paint Guns 14.99, I am going to have to take them to an experienced painter and have him explain what all the adjustments do.
New 50ft air line. 200psi working pressure with 800psi burst pressure. On sale for 9.99 I can't wait to get back and play with these. I'll post more about the other tools in my Vacation thread. (don't want to muck up this thread with non related info. |
ZeroC
Senior Member Joined: 12 February 2007 Location: Canada Status: Offline Points: 346 |
Post Options Quote Reply Posted: 20 March 2009 at 1:01pm |
you have a filter for your compressor ...if your planning on painting
nothing like a lil extra water in the paint to really screw stuff up |
Post Options Quote Reply Posted: 21 March 2009 at 2:58pm |
Yep will be installing a dryer a moisture trap and a water bleeder between the main and secondary air tanks.
Post Options Quote Reply Posted: 23 March 2009 at 12:48am |
well just an update on the build. Here are the tools we picked up today. picked up a line dryer with a filter installed. Well first off some of the finds in the flea markets and small little shops we were in. It is very obviously a Fiero, however with some popular mods like Mecham Side Scoops, aftermarket wheels and over the roof scoop. Even has pop up lights that have twin projectors in it. However an odd mod, it has the Back seats in it, like GM was planning to build. Picked up a Craftsman drop light with coil for 10 bucks Dryer
Post Options Quote Reply Posted: 23 March 2009 at 10:19pm |
So I went out and bought a little in-line drier. Its the blue thing beside the big thing in the photo. I had posted the pics and received a message from the good Dr. that, that dryer is pretty much junk and should only be used as a secondary cleaner after a much larger dryer, as well as the regulator I bought was not going to work. So Today we went back out to Harbor Freight and picked up a few things.
The Box Note the pen beside it as a size reference Assembled and showing the dryer I thought was big enough Side View Specs, sorry for the blurry 3 head manifold. This way I can have a dedicated line and parts from the tank to the paint gun and worry a little bit less about running the other power tools on the lines. I figured for 10 bucks it was cheap insurance.
Post Options Quote Reply Posted: 29 March 2009 at 11:15pm |
This will be perfect to have it installed in the front compartment remote battery mount. Well is one of the piles of stuff I have picked up. We went back yesterday and looked around, I tried to go back today but ran late and they were already closed. Battery Disconnect. Key in Key Removed Paint Guns, 2 larger runs and 1 detail gun. Finally a Tap and Die kit. Until know I have just taken a good bolt with grease on it and fired it in with my air impact gun and hope that the bolt is stronger than the threads I am trying to repair. So this will come in really handy. Socket Trays Re-usable Spray can. Fill it with anything charge it up to 90psi with an Air compressor and you are good to go. |
