87 GT- Inside and out |
Page 123> |
Stevenr ![]() Member ![]() Joined: 12 February 2012 Location: Canada Status: Offline Points: 85 |
![]() ![]() ![]() ![]() Posted: 11 March 2012 at 5:57pm |
Since I officially started to do some work on my car, I
figured I might as well post it up with progress as it happens. Rough outline of my plans( may take 10 years, who knows) EXTERIOR: -Chin spoiler -Lowered w/ 17" rims -V8 Archie Rocker Panels -Body work to fix fitment issues -Paintjob, undecided colour INTERIOR: -Mr. Mikes Leather seats/arm rest/ebrake and shifter boot in Black/grey -Paint door panel carpet black with grey accents -Paint Dash/console black -Full sound system w/ custom 8" sub box in place of center console glovebox I'll be updating this thread as I finish projects, but as this is a long term project, It may be a while between posts. |
Using Vinyl/Fabric paint, I refinished the door panel and
handle to match the incoming interior. See below for pictures, apparently I can't figure this out ![]() |
add [IMG ] before and [/IMG ] after the link (without the spaces)
Or, since your using photobucket, copy the IMG tags from the picture on photobucket and paste those Before: ![]() After: ![]() Looks good |
I'll do the other door tomorrow, and perhaps pick up a grey
that's a bit closer to the door for the map pockets. |
Second door done, might do the map pockets with the darker grey
tommorrow. Audio is all going in this weekend. |
The doors look awesome! Like a factory option! Here's hoping everything comes together with no hiccups for you.
Thanks Romeo, but the more I read, the more I don't think
that will happen ![]() Also changing plans, will be going V8 archie Rocker panels instead of the Side scoops. |
Deck was installed after about 5 hours of failure. Lots of
small things wrong with old cars! ![]() SubWoofer and Amp will be going in this coming weekend hopefully. |
Made some progress, cleaned up the center console, made some
touch ups, and painted the passenger floor mat to match the door. Pics will be uploaded tonight. Also mocked up the sub in the center console, but im worried with the sub magnet being so close to the ECM, so im going to buy an already made one that mounts further forward, also will probably look better ![]() |
Center Console Subbox ordered, should be here in two
weeks approx. Changed my plans: V8 Archie Hatchback in place of Choptop V8 Archie Rocker Panels in place of 2.1 side scoops Once it get's nice/hot consistently, I'm going to re-do the spray can job properly so it looks decent Also going to go to Pick-apart this weekend and see if that front bumper is still there, and try and get started on the front lip. |
Today was a beautiful day, so I decided to try and fix
the sagging rear bumper. Good news, I fixed the rear bumper, also sanded down a bit, and rust-oleum'd the metal bumper behind. Bad news, I'm feeling pretty overwhelmed by the overall shape of the exterior... Might have to add new Fiberglass front and rear bumper to my wishlist. Also the paint is starting to crack, orange peel everywhere, and a large bubble on the hood. When it's time to repaint this thing, do you guys suggest sanding ALL the spray paint down? |
Little update, been to rainy to work on the car, but have
been driving it quite a bit. The battery died, so I got a new battery for it, the sub/audio system will need a good battery anyways. Center subbox/console is on it's way, then I'll get the rest of the system installed. Official plans: Fiberglass front bumper with chin spoiler, V8 archie rockers. Once that's all aquired, going to assemble it, sand everything down to original paint or down to plastic, then just use black primer for now. I'm shy'd away from spray-painting it since eventually I'll want to get a real, quality paintjob and spraypaint will significantly increase the cost. |
To do a quality paint job, they need to sand a fair bit off anyway. I'm
not sure it matters whether you have rattle can paint or not. An old car like this needs to be prepped right either way. You may as well try and make her look as nice as possible till you can afford the full meal deal. We could talk more about bodywork at the tech session if you like. Bring the supplies and we could do a small patch somewhere to show you the way. Dawg |
Talk to Dr. Fiero, he bought a complete HVLP system that runs off of basically an over rated vacuume cleaner in reverse. Blower, Sprayer and all is only around $200 at Princess Auto, and we used it to shoot my Black 857 GT V8 into primer and it came out really well. Good enough to take 2nd place at the All Pontiac show in the fastback class. P.S. Dawg from what I have been told the chemicle in spray bombs that is used to cure the paint, actully soaks into the eurathane (sp) panels on the Fiero's and makes them really hard to spray correctly later. Which is why I replaced all the panels on my car and sanded the hell out of the rest of them.
Sounds good :)
Yes, I've been reading that something about the spray paint will not bond properly with proper Automotive paint, which will require having it completely sanded down, severely increasing labor. I'll just leave it in a black primer until I'm ready for a "real" paintjob. Question for the electrically inclined folks...( copied from PFF): Hey everyone, I purchased an aftermarket stereo system including: Stock front and rear speakers(for now) Alpine CDE-121 deck Pioneer AMP 8" Kicker sub for the center console Now, after much over broken parts, and general old condition of the HVAC console, we got the deck installed. The AMP and sub will be installed when the center console/subbox arrive. Now for the problem... when we were installing it, (Couldn't find a wiring harness) there was no accesory wire to connect to the decks accessory wire. So temporarily, I've got it routed into the fuse box just to see if it works. The deck works, sounds good, but turns off when you turn off the motor even if the accessory stage is still on,stall, etc. Are there any other options to wire this so it will turn on and stay on with the interior lights, and not actually starting it? |
Got the head unit fixed, that was actually quite fun :)
SubBox/center console should be arriving within the week.
Going to re-do the firewall and door carpet with some leather-ette or vinyl, get black carpet, and Mr-mikes within the next month hopefully. Then a new steering wheel and pedals will be in order. Body work starts soon, then I'll be trying something I've found... Also going to add a new ground wire, see if that helps windows/gauges and idling. Only question, what color for the the two-tone to match the exterior? I can't decide on a color! |
Mr Mikes seats and interior kits ordered!
Subbox/center console is MIA... emailed several times, starting to panic. |
Center Console finally arrived after a few emails back
and forth. It arrived, and is now clear that the piece has many issues. - Clear that a mistake was made, piece was glued back into the shifter portion. -Shifter portion positioned/cut wrong, cannot shift into 2nd or 4th. -Power control portion cut wrong, large gap. -Sides of box has 1/2 inch gap between carpet and box. Overall, very dissapointed/angry about this situation, after waiting so long only to have a poorly made product arrive. |
Nothing happening with the dealer, so I'm stuck with
it... but I'm making it work. Progress: Subbox has been re-cut to fit the shifter properly, and the power window switches are molded in, rather than being about an inch below. Half way through installing the actual Sub, it's looking good though! Yesterday I got a new front bumper in mint condition from Dr.Fiero, had a nice chat, and the front lip project will now start once I swap bumpers. Mr.Mikes seats, lower door skins, and firewall cover on their way. Also covered all the dash bezels in Carbon Fiber Vinyl/wrap material, looks identical to the 300$ dash kit from fieroshop, but cost me 30$. Will try to get some pictures tonight, I know a build thread is nothing without pictures! |
Page 123> |
