Free 85GT Chassie |
![]() ![]() ![]() ![]() Posted: 06 April 2009 at 8:00pm |
This is stripped to the bone. I want this gone ASAP. No suspension No Interior No Doors No Wiring No drive train No rear window Front Windshield is still there, and in good shape. No Body panels of any kind. Only use would be to mock up custom body panels. Or take it to the recyclers for a couple bucks.
I'll be posting it on Craig's list shortly. I won't be holding it for people, first person to come with a flat deck and a few buddies to pick it up and put it on the truck gets it. I am serious 4 strong guys or 6 regular guys can probably pick this up and drop it on a truck. Its currently sitting about 2ft off the ground on 4 tall jack stands. I need it gone ASAP.
These pics show the doors still on, but the doors are removed and gone now.
garrym ![]() Member ![]() ![]() Joined: 09 December 2007 Location: Canada Status: Offline Points: 53 |
can i have the windshield?
If you can get here before it goes to scrap and you remove it, its yours. Address is 16908 104th Ave Surrey B.C. Call me on my cell 604-807-2623 to arrange a time to come. I will be home all day tomorrow sorting tools and I have a another member stopping by to chat while I am cleaning things.
yea i will stop by tomorrow for sure, i am at school untill 3 so around 330-430 abouts, not sure how to remove it without breaking it. but im sure i will find a way, ill bring a friend to help and put it into my car. currently my fiero is at my friends place as i have no where to put it.
thank you for your help on this, |
Easiest way to remove it is with piano wire or bicycle brake cable, one person sits in the car and the other outside the car and move the cable back and fourth like a saw, dragging the cable around the frame. As you go, you should put wedges of some sort to keep the glass away from the frame so it does not re-stick down. We removed the rear window from the car which 80% of people I talked to said it was damn near impossible. I actually used a small propane torch to heat the glue/glass to make it easier to cut it out. I have several metal wedges here that I used. I know its a bad idea, steel on glass, but thats what I had and it worked. If your dad hauls scrap, maybe you could get him to take the entire car and then you can remove it at your leisure. Regardless I need the car gone as I need the spot to put a family car we are going to be buying. P.S. anyone interested in buying an 88 Dodge Caravan, seats 7 comfortably. $1000 obo well take 800 cash. New Trans was $1800 less than 10,000 kms ago, new tires less than 2000kms ago. Even has an MSD Blaster II Coil installed. 3.0L Overhead Cam V6. |
I asked my dad doesnt want it apperently scrap isnt worth a whole lot right now but i still want the glass, i will be there tomorrow and thats a great idea, I will call you tomorrow my number is 778-322-9051
