  New Posts New Posts RSS Feed - 18"
18"
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Topic: 18"
    Posted: 18 November 2008 at 7:27pm
I've heard that the largest rim the Fiero can handle is 17", however a local car shop is selling a BEAUTIFUL set of 18" rims for only $400 (they include tires). Does anyone know if it's possible to run that large a diametre on a stock suspension and body set-up?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2008 at 7:32pm
The stock Fiero suspension can handle up to a 22" rim with the right tires.   Smurf had 20's on his Fiero. Ryan now owns the car. (88forumla)  There are dozens and dozens of people running 18's on there cars.
Edited by Capt Fiero
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2008 at 12:35am
Okie dokie. They're pretty low profile, so it might work. I'd better check the width I guess though. Thanks for the advice! =)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2008 at 8:50am
http://www.dakota-truck.net/TIRECALC/tirecalc.html
225/20/22 will fit without rubbing or rasing the car, even your speedo will be almost correct.  Out buy just a few KM's an hour.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2008 at 8:57am
This 18 is almost an exact match for the stock 15" lace wheels.
Dimensions
Dimension Tire A: 215/60 R 15
(25 x 8.46 x 15)
Tire B: 225/40 R 18
(25 x 8.86 x 18)
Difference
Width
Sidewall height
Overall height
Circumference
8.46" (215.00mm)
5.08" (129.00mm)
25.16" (639.00mm)
79.03" (2007.48mm)
8.86" (225.00mm)
3.54" (90.00mm)
25.09" (637.20mm)
78.81" (2001.82mm)
+0.39" (+10.00mm)
-1.54" (-39.00mm)
-0.07" (-1.80mm)
-0.22" (-5.65mm)
Speedometer Error
Actual Speed Indicated Speed with Tire B Speedometer Error
5 mph (8.04 kph) 5.01 mph (8.07 kph) +0.01 mph (+0.02 kph)
10 mph (16.09 kph) 10.03 mph (16.14 kph) +0.03 mph (+0.05 kph)
15 mph (24.13 kph) 15.04 mph (24.20 kph) +0.04 mph (+0.07 kph)
20 mph (32.18 kph) 20.06 mph (32.27 kph) +0.06 mph (+0.09 kph)
25 mph (40.23 kph) 25.07 mph (40.34 kph) +0.07 mph (+0.11 kph)
30 mph (48.27 kph) 30.08 mph (48.41 kph) +0.08 mph (+0.14 kph)
35 mph (56.31 kph) 35.10 mph (56.47 kph) +0.10 mph (+0.16 kph)
40 mph (64.36 kph) 40.11 mph (64.54 kph) +0.11 mph (+0.18 kph)
45 mph (72.41 kph) 45.13 mph (72.61 kph) +0.13 mph (+0.20 kph)
50 mph (80.45 kph) 50.14 mph (80.68 kph) +0.14 mph (+0.23 kph)
55 mph (88.50 kph) 55.16 mph (88.74 kph) +0.16 mph (+0.25 kph)
60 mph (96.54 kph) 60.17 mph (96.81 kph) +0.17 mph (+0.27 kph)
65 mph (104.58 kph) 65.18 mph (104.88 kph) +0.18 mph (+0.30 kph)
70 mph (112.63 kph) 70.20 mph (112.95 kph) +0.20 mph (+0.32 kph)
75 mph (120.67 kph) 75.21 mph (121.02 kph) +0.21 mph (+0.34 kph)
80 mph (128.72 kph) 80.23 mph (129.08 kph) +0.23 mph (+0.36 kph)
85 mph (136.76 kph) 85.24 mph (137.15 kph) +0.24 mph (+0.39 kph)
90 mph (144.81 kph) 90.25 mph (145.22 kph) +0.25 mph (+0.41 kph)
95 mph (152.85 kph) 95.27 mph (153.29 kph) +0.27 mph (+0.43 kph)
100 mph (160.90 kph) 100.28 mph (161.35 kph) +0.28 mph (+0.45 kph)
105 mph (168.94 kph) 105.30 mph (169.42 kph) +0.30 mph (+0.48 kph)
110 mph (176.99 kph) 110.31 mph (177.49 kph) +0.31 mph (+0.50 kph)
115 mph (185.03 kph) 115.32 mph (185.56 kph) +0.32 mph (+0.52 kph)
120 mph (193.08 kph) 120.34 mph (193.63 kph) +0.34 mph (+0.55 kph)
125 mph (201.12 kph) 125.35 mph (201.69 kph) +0.35 mph (+0.57 kph)
130 mph (209.17 kph) 130.37 mph (209.76 kph) +0.37 mph (+0.59 kph)
135 mph (217.22 kph) 135.38 mph (217.83 kph) +0.38 mph (+0.61 kph)
140 mph (225.26 kph) 140.40 mph (225.90 kph) +0.40 mph (+0.64 kph)
145 mph (233.31 kph) 145.41 mph (233.96 kph) +0.41 mph (+0.66 kph)
150 mph (241.35 kph) 150.42 mph (242.03 kph) +0.42 mph (+0.68 kph)
155 mph (249.40 kph) 155.44 mph (250.10 kph) +0.44 mph (+0.70 kph)
160 mph (257.44 kph) 160.45 mph (258.17 kph) +0.45 mph (+0.73 kph)
165 mph (265.49 kph) 165.47 mph (266.23 kph) +0.47 mph (+0.75 kph)
170 mph (273.53 kph) 170.48 mph (274.30 kph) +0.48 mph (+0.77 kph)
175 mph (281.57 kph) 175.49 mph (282.37 kph) +0.49 mph (+0.80 kph)
180 mph (289.62 kph) 180.51 mph (290.44 kph) +0.51 mph (+0.82 kph)
185 mph (297.67 kph) 185.52 mph (298.51 kph) +0.52 mph (+0.84 kph)
190 mph (305.71 kph) 190.54 mph (306.57 kph) +0.54 mph (+0.86 kph)
195 mph (313.75 kph) 195.55 mph (314.64 kph) +0.55 mph (+0.89 kph)
200 mph (321.80 kph) 200.56 mph (322.71 kph) +0.56 mph (+0.91 kph)
If your speedometer has been calibrated for 215/60 R 15 (25 x 8.46 x 15) tires, replacing them with 225/40 R 18's (29 x 8.86 x 18's) would result in the speedometer reading high by 0.28%.
Odometer Error
Actual Mileage Indicated Mileage with Tire B Odometer Error
1 mi (1.61 km) 1.00 mi (1.61 km) +0.00 mi (+0.00 km)
5 mi (8.04 km) 5.01 mi (8.07 km) +0.01 mi (+0.02 km)
10 mi (16.09 km) 10.03 mi (16.14 km) +0.03 mi (+0.05 km)
50 mi (80.45 km) 50.14 mi (80.68 km) +0.14 mi (+0.23 km)
100 mi (160.90 km) 100.28 mi (161.35 km) +0.28 mi (+0.45 km)
500 mi (804.50 km) 501.41 mi (806.77 km) +1.41 mi (+2.27 km)
1000 mi (1609.00 km) 1002.82 mi (1613.55 km) +2.82 mi (+4.55 km)
5000 mi (8045.00 km) 5014.12 mi (8067.73 km) +14.12 mi (+22.73 km)
10000 mi (16090.00 km) 10028.25 mi (16135.45 km) +28.25 mi (+45.45 km)
50000 mi (80450.00 km) 50141.24 mi (80677.26 km) +141.24 mi (+227.26 km)
100000 mi (160900.00 km) 100282.48 mi (161354.52 km) +282.48 mi (+454.52 km)
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2008 at 11:58am
Awesome. They had been for a VW Jetta, so width wise I think they'll be fine.
