  New Posts New Posts RSS Feed - One more Air Care story
Blair View Drop Down
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Topic: One more Air Care story
    Posted: 15 September 2007 at 6:06pm
I took my 87 coupe through Air Care today and it failed!          ;       This was the first time on the road for the car after rebuilding the Duke. I drove over 100k trying to burn the old gas in the tank, This moved the needle on the guage just over an 1/8. I gave up and tested the car with 1/3 old gas.         &n bsp;         &n bsp;         &n bsp;         &n bsp;          On the driving test I failed NOx - 2584. on a max of 2378.  Not bad but on the idle test I did an HC of 1194. on a max of 306.  Oops.  I'm thinking a new cat may not fix this, What do you think?
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2007 at 6:08pm
Ps What is &n bsp and why is it there?
Graeme View Drop Down
Post Options Post Options   Quote Graeme Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2007 at 7:24pm
Without the space in there, it's the programmatic equivalent of a space. Not sure why it is showing up when you post. What browser are you using.
On a note about air care, mine breezed through last week with very minimal readings. A bit of a relief.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2007 at 10:01pm
Some of the high readings can because the engine is still "too new"!
It'll still be really tight (tolerances wise).
As for the high NOX - what plugs are you running?  I've always found the stock recommended ones to be too hot (especially Motorcraft ones!).  Pull the plugs and read the colors on all of them.
A new 3 bed (2 bed one won't do anything for NOX) CAT might help to pull some of the readings down, but...
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2007 at 7:07am
Last week I past both 85s through Air Care with no problem but the 87 dukes are a little harder to pass. Irwin was having problems with his 87 as well.
The plugs are ngks from the Lordco computer. I'll pull them for a reading later but I think that I will burn the old gas off before I test it again. Maybe that will loosen the engine up a bit as well.
One think I know is Air Care is a pain in the ______ !   Between Ang and I we have 5 car to test every year just to drive then once in a while. They need a limited use insurance that is Air Care free. Like commercial trucks , pickups over ____gvw, and motor cycles.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2007 at 12:27pm
Blair do you have any way to scan and post up a copy of the aircare sheet, I would love to compare the numbers to what the 88V6's are allowed.
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2007 at 3:50pm
Driving test- Hydrocarbons 91 on a max of 226.
                   Carbon Monoxide 0.38 on a max of 1.64
                   Oxides of Nitrogen 2584. on a max of 2378.
Idle test-     Hydrocarbons 1194. on a max of 306.
                   Carbon Monoxide 1.06 on a max of 3.59
My 85 2m4 with 250,000+km tested much better and makes me think burning oil is the way to go.
Driving test-  HC 33. on a max of 234.
                     CO 0.00 on a max of 1.68
                     NOx 275. on a max of 2432
Idle test-      HC 24. on a max of 390.
                     CO 0.00 on a max of 4.43
Maybe I should keep this motor for passing Air Care.
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2007 at 6:59am
I used a timing light to watch the spray pattern of the injector. The fuel gobs matched the pops coming from the tail pipe. I will replace the injector and retest the car.
On a side note, the car has a 86 Isuzu 5 speed. At 125 kmh in 5th gear the engine is reving at 4,000 rpm. This is a Fiero trans but 410 gears on a 5 speed? (All other gears are low as well.)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2007 at 4:44pm
Sounds like you ended up with an Isuzu that was originally out of a front drive sedan, same issue I had with the front drive trans axle in my 4.9.   There seem to be a bunch of different ratio Isuzu's out there, and only the genuine Fiero Isuzu had the good highway gears.
As for knowing how to tell, the only way I can check them is by turning the input shaft and watching the output shaft rotations.   No one seems to know what numbers are what on the outside of the trans.
