  New Posts New Posts RSS Feed - Rear Sway Bar
Rear Sway Bar
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Topic: Rear Sway Bar
    Posted: 10 March 2007 at 11:01am
Can anyone help me on the choice or explaination of which does what:).
I am looking at Rear Strut Tower Brace and Rear Lower Heavy Duty Sway Bar...does one need both or one or the other, etc.
Thanks
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2007 at 1:26pm
The strut tower brace is not really needed on a V6 especially if you have not hacked up the OEM trunk wall brace that goes between the struts. (its under the carpet) As for a rear sway bar, they make the car into a real sports car feel, there is a night and day difference with a rear sway bar.
Talk to Blair and Smurf about it, they have both recently done sway bar installs on there cars, and both really enjoy them.  Lisa's V8 has one, I use to have one on my V6 but have not re-installed it since I put in my V8.  I really should I have just not gotten around to it.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2007 at 8:42am
If you opt to do it, look into Rodney's sway bar joint kit.  He did up a set just for that purpose, and it ends up be a WAY nicer job than just using shortened front links.  Tim's got a set on his car.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2007 at 1:36pm
If they are a solid joint rather than a bolt through with poly, they will work much better.  I will end up getting something like that when I redo my sway bar.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2007 at 6:19pm
It's kind of hard to explain (boy would a picture do wonders here now!) - It's like an outer tie rod end, but really small!  Same on each end, and a short link in-between.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2007 at 7:33pm
I will look at Tim's set up...but other than Fiero Store, can we buy the front & back sway bars locally?.  Their kits say they provide the hardware...I look at Dickman's and couldn't find the kit David.
Think I'll get the ball joints, tie rods, etc. done first then 2nd stage the sway bars
Thanks
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2007 at 9:07pm
I just went to Rodney's site and could not find it myself.  That's totally odd.  I sent on an email to him asking about it.  When he gets back to my I will post his reply.
This is how Lisa's sway bar is mounted.
Blair View Drop Down
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2007 at 6:37am
Here's the front sway bar mounted in the rear.
The way this is mounted it will only work with cars
that have had the e-brake removed. Working on that.
How-to thread to come.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2007 at 9:11pm
Hey Blair,
Creative as you usually are:).  Are the sway bars available locally?...we'll chat, like to get the rest of the suspension done first:).
Cheers, Bb
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2007 at 9:30pm
This is what Rodney sent me and it is not what I was thinking it was.
Post Options Post Options   Quote Blair Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2007 at 6:31am
Hey Blair,
Cheers, Bb
It's a stock Fiero front sway bar. Available from club members and
scrap yards in your local area.
