  New Posts New Posts RSS Feed - When car is hot it will not start
85SEnochie View Drop Down
Post Options Post Options   Quote 85SEnochie Quote  Post ReplyReply Direct Link To This Post Topic: When car is hot it will not start
    Posted: 29 September 2008 at 9:37am
I replaced six of the fuel injectors did not replace the cold start injector It will start great when it is cold but when its hot it will not Fire. When the car is hot the oil presher drops to nearly nothing at an ideal bring the RPMs up to a little over a grand the presher light goes off. PLEASE help
Edited by 85SEnochie
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2008 at 11:31am
Well if I read your post on the nwfieros group correctly, you need to do 2 things, replace the starter and move up a thickness in oil. If you are using 5w30 I would move to 10w30 or 15w40 if you are already at 10w30, I would move to 20w50.
Post Options Post Options   Quote 85SEnochie Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2008 at 11:36am
5w30 is what I am using I will try that Sorry dont type very well or not as well as I photo chop anyway the starter is working the tach is bouncing but will not fire
