heat smell |
Guests ![]() Guest ![]() |
![]() ![]() ![]() ![]() Posted: 01 May 2007 at 10:44pm |
hey guys sorry with all the questions but i ahve another question, but wen i use my heat or turn the dial to like warm or hot, it smells wat do u think it is? i have 1986 pontiac fiero gt fastback
Probably a leaking heater core. Keep an eye on your water level in the cooling system.
If the car is A/C it is very easy to change, if the car does not have AC it is a bit more work, but still very easy. In either case, a mechanic will take less than an hour to do it. |
i got a new ehater core put in adn everythign only wen i use the warm air it does it
If you had just replaced your heater core, it is possible some coolant got spilled into the venting. Hence when you turn on the heat, the smell of the coolant gets blown into the cabin. On the other hand, the heater core swivels to open and shut the vent (heat exchange) and the coolant in the core is connected to the cooling system via rubber hoses. It is possible those hoses need replacing also. Good luck with it.... |
Blair ![]() Senior Member ![]() Joined: 12 February 2007 Location: Canada Status: Offline Points: 250 |
When I first got my GT it smelled of antifreeze. I changed the heater core only to find out that the core had already been changed. For the next 2 years I could smell antifreeze when the heater was on. I assume that antifreeze had gone into the vents and the residue is what I was smelling. Unless you took the heater apart and cleaned it when the heater core was replaced this could be the problem. |
Another thought - this person never actually said 'smells antifreeze'!
Are you smelling that, or mold, or a dead herring, or...... ???? |
i dont think its antifreeze i think its liek mold or mildew or sumthin |
Hit up your local auto parts place.
There's stuff you can get in a spray can that is for cleaning out mold in air conditioning systems. You spray it down your air intake (usually with all the doors and windows closed, A/C on high - NOBODY in the car!!!!). The air intake is got to by popping the front hood - look right around the passenger side windshield wiper - see the vent/grill? Just put your hand there with the fan on high and you'll feel it sucking in. |
John do you think that will help with the musty, stale air smell usually associated with A/C systems.
Yes - that's what the stuff is intended for.
Kills the mold spores that cause the smell. |
