Help on replacing a window |
Talykashykun
Newbie Joined: 21 April 2013 Location: United States Status: Offline Points: 2 |
Topic: Help on replacing a window Posted: 21 April 2013 at 10:21pm |
New user here, but a friend of mine pointed me this way.
Just the other day a worthless you know what decided to bust my driver's side window and steal my $30 CD player sometime in the night, and leave me pretty fuming the next day when a neighbor came to tell me that my window was busted. Not only was my window broken, but there's a big gash on the paneling right next to the door by the driver's side head rest, my center console has a large crack in it from probably a crowbar, and my power window motor looks like it has collapsed. My question is how would a d.i.y. guy go about finding the easiest/cheapest solution to replace and fix these parts because, to my knowledge, Houston is pretty dry when it comes to Fieros. Here's a link to the carnage in my car showing the damages: http://imgur.com/a/faWgQ And here's how the car is normally, all nice and unvandalized :( http://imgur.com/hTPYsmS |
ZeroC
Senior Member Joined: 12 February 2007 Location: Canada Status: Offline Points: 346 |
Post Options Quote Reply Posted: 21 April 2013 at 11:31pm |
ahh too bad your not local ..i just pulled a door glass from my car ...drivers side too :) ....once you remove the inside door panel you will see the window regulator on the regulator it will have some giant white pins/roller / stupid ass gm design ..these are attached with some big rivets ....depending on the glass you get ....these may allready be on the glass...hopefully they are ...should be as simple as just putting new rivits in ..
having said that its a fiero ..and nothing is ever simple lol good luck :) |
Talykashykun
Post Options Quote Reply Posted: 22 April 2013 at 2:31pm |
Yeah, I remember looking at the tutorial to change the sail
panels, nope'd on that one after a while. And If I trusted the postal system I would buy yours off of you if possible lol, but yeah so far local junkyards are pulling up zilch, just a bunch of beat up Toyotas. |
