Home made cheap penetrating oil.? |
Topic: Home made cheap penetrating oil.? Posted: 04 November 2009 at 11:30pm |
This was just posted on the main international Fiero list, Looks really interesting. Might be a nice replacement for all the crap I keep paying 10-20 bucks a can for.
------------------------------------------------------------ ------------------ All, __._,_.___ Reply to sender | Reply to group Recent Activity: · New Members 9 Visit Your Group Start a New Topic -- |
Patrick
Post Options Quote Reply Posted: 05 November 2009 at 12:27am |
That's quite interesting. I googled the info and came up with this...
I'd always been told PB Blaster was the best commercially available stuff. Hmmm... I may have to change what I use.
Post Options Quote Reply Posted: 05 November 2009 at 12:36am |
Now correct me if I am wrong isn't acetone the primary ingredient in ladies nail polish remover? Which I know you can buy at the $1 store. Hmm wonder if you need ford or Chevy ATF. LOL. I may have to whip some of these up for this engine swap I am doing . I Also have that pressure tank with spray adapters. (re chargeable aerosol spray can) |
Patrick
Post Options Quote Reply Posted: 05 November 2009 at 12:48am |
I googled acetone and discovered that it is indeed the "active" ingredient in nail polish remover, but that also leads me to suspect that there might be other crap in there you wouldn't want as part of your "home brew" penetrant. Acetone is sold in the paint section of Can Tire, Home Depot, Rona, etc. Shouldn't be very expensive.
Dr.Fiero
Post Options Quote Reply Posted: 05 November 2009 at 7:23am |
Keep in mind too.... Acetone is SUPER dangerous, especially when aerated! The fumes WILL kill you, and WILL burn like crazy.
Ever wondered where acetylene (as in the gas used in torches) comes from? You got it... acetone! Oh yeah, it'll also melt almost any bottle short of glass or metal you put it in, and it'll destroy the seals in most pump mechanisms. Fun stuff though! |
Post Options Quote Reply Posted: 05 November 2009 at 10:15am |
My pressure can is metal. So I should be fine.
Sounds like this stuff would make a great flame thrower. I don't know if the spray nozzles will handle it. I do have a remove solvent tank sprayer that hooks to my compressor that is all steel. However its way to huge to use like a spray can. Its meant for spraying an entire engine, not just one bolt on an engine. |
Patrick
Post Options Quote Reply Posted: 05 November 2009 at 10:32am |
So many times when I've used PB Blaster I've cursed the fact that when it's sprayed on so much is wasted. And it's not just because I'm a poor aim. I've sometimes gone to the trouble of spraying it into a small bottle cap so that I can then pour it onto whatever nut or bolt I'm trying to loosen. Not being able to spray a "home brew" penetrant isn't much of an issue for me at all.
Dr.Fiero
Post Options Quote Reply Posted: 05 November 2009 at 1:25pm |
Can is metal. Yup. Betcha all the rubber seals in it are... well... rubber....
ARTIC-1
Post Options Quote Reply Posted: 05 November 2009 at 6:07pm |
acetone! nasty stuff,bin around it for years in the marine biz,goes rite to
your liver with in a min,yep that fast.we were sitting arround the shipyard one day at lunch an one of the fiber glassers guys showed us just how fast it goes threw your body.he puts a little pice of orange peel in the palm of my hand an then about a spoon full of acetone! on top of it, with in 30 sec i could taste orange in your mouth,@#!$ unreal,i wouldn't suggest you try this,but if you have see for yourself,have at her.it not enough to harm you so be careful with it guys.an when you presserize it .it becomes real unstable @350psi-nitro like. |
Patrick
Post Options Quote Reply Posted: 05 November 2009 at 7:44pm |
Ooops, I guess I shouldn't have tried using it today to wipe the greasy dirt off my hands after working on the Fiero. I bought some today ($6 at Rona for 1/2 liter) to mix up some "home brew" penetrant, and I actually did use it to wipe off my hands. It felt quite cool to the touch, but didn't really do that good of a job on my hands. Hopefully it didn't do a good job on my liver either. I won't be doing that again!
