I ran into a problem on saturday.. |
Jordandsd ![]() Newbie ![]() Joined: 26 December 2013 Location: Canada Status: Offline Points: 21 |
![]() ![]() ![]() ![]() Posted: 16 February 2014 at 12:57pm |
I insured the fiero on saturday night for a cruise out to
white rock to pick new rims up for my 1978 monte carlo... well on my way back i was on the highway and i went to shift to 5th and pushed the clutch in and went to shift but my shifter was stuck solid.. so i held the clutch in a rolled down a ramp and luckily rolled into a gas station. So i got there and popped the hood and checked my clutch fluid level..it seemed fine.. then i checked trans fluid and it was fine. I sat there puzzled when the car was off i could change my gears but on i couldnt.. so i got my step dad to come out and have a look with me.. we just put it in 2nd and tried to hobble it home to langley... well i only made it 2 blocks and hit a red light so i whipped into a parking lot because i couldnt get it back in gear.. so when i got there i shut it off and popped the hood again. checked the fluid again of the clutch fluid.. and it was dry. i looked under the car and fluid was under it.. then i popped the deck lid and found that the rubber boot on the Clutch slave had a pin hole... so since every store was closed for clutch fluid i got dot 3 brake fluid and filled er up.. on my way back to langley i had clutch again... and i parked it. now for the next thing.. iv never replaced one of these on a fiero... is it hard and does anyone recommend anything.. was my clutch not working because of that pin hole in the rubber boot.. i dont know if that boot is pressurized or anything. HELLLPPP lol thanks guys ![]() |
Unless the previous owner used something exotic, that's what you wanted. Now's the time to upgrade to Rodney Dickman's double-seal slave cylinder. It's the best $65.95 you'll ever spend on your Fiero. This will fix your clutch hydraulic problems for years (or until your clutch master cylinder eventually wears out).
Fieroman88 ![]() Moderator Group ![]() ![]() Executive Member Joined: 09 January 2011 Location: Canada Status: Offline Points: 298 |
Hey Jordan Its easy. If you need the service manual to
borrow, let me know and you can use mine. Just email me Glenn |
Fieroman88
Thanks for the help guys! Ill try and get this done as
soon as the Rodney Dickmans double seal cylinder shows up ![]() |
monzaguy ![]() Newbie ![]() Joined: 03 May 2014 Location: Canada Status: Offline Points: 9 |
Hi, Im one of the new guys here. Bought my first ever
"New to me Fiero" a couple a weeks ago. An 85 SE with 121 thou on the odomiter. Nice 17 inch rims with new tires,and a 5 yr old Black paint job. Needs a bit a work too,but nothin too difficult.Would like to find a good "Canadian" source for much needed parts,rather than go through the US and the outrages shipping charges. Here is my problem in a nutshell. The car came out of Yellowknife arround 6 years ago, and the owner basicly drove it till the plates expired,then parked it in his garage. Im in Alberta,and need an OPI done, prior to getting it regestered. Battery was toast (sat too long) and the alternator is also toast. Bought both new and she came out of hibernation after a good shot of Octane boost and 3 attempts,she purred like a kitten (needs a catt) or can one get away with just a test pipe? Will take pix as I progress towards the OPI. Definately needs a battery tray, and Im sure to find other things it needs. Anything I should pay close attention too? Power windows are a little slow but work,as do the power mirrors,and the AC. Is there a conversion on the market for the AC? At some point I would like to convert the auto trans to a 5 or even a 6 speed. |
Canadian suppliers are to find:(
If the part is not Fiero specific, such as engine parts
(gaskets, oil pumps, spark plug cables etc), some suspension pieces (bushings, shocks, struts), you can get them from places like Lordco, Napa, and my buddy at Magnem Engines in Burnaby. Fiero specific parts are hit n miss at these places. Some just not available and you fashion your own replacement parts. Or you deal with Fiero specific shops in the US. This is an issue with any 30 year old car. Good luck. Any pictures of your ride? We love pictures here. |
Mickey_Moose ![]() Newbie ![]() ![]() Joined: 30 July 2014 Location: Canada Status: Offline Points: 6 |
Hi monzaguy,
Just a note that the power windows are normally 'slow' when compared to other cars out there. Rodney Dickman sells a speed "booster" for the windows that is suppose to help (haven't tried it) - the only other option is to retro fit a newer motor into the door. Granted yours could be slow due to hardened grease and what not, but don't expect them to be fast after you clean up the tracks and such. ;) Fiero specifics parts either used from a wreckers (only place in Canada that would sell them) otherwise it is from the US (never use UPS to ship, always USPS - talk to the vendor about using it before you order, some default to UPS). Most general parts, as said can be bought anyplace that sells auto parts (Dash Automotive in Edmonton is usually a good source - you would have to contact Tony with Calgary Fiero club to find out the options there). |
