  New Posts New Posts RSS Feed - Need some advice PLEASE
Chris38 View Drop Down
Post Options Post Options   Quote Chris38 Quote  Post ReplyReply Direct Link To This Post Topic: Need some advice PLEASE
    Posted: 25 May 2016 at 4:46pm
I am new here. I have a 87 fiero 4 cylinder. Replaced a faulty fuel pump and car ran excellent for one day.
Now it seems the duke starts and idles good in park revs in park also, sounds good.
As soon as you put it in gear and give it throttle it pops and backfires through intake. Here is a list of thing done.
New plugs ac delco
New plug wires
New map sensor
Compression check 125 all 4
Fuel pressure check 20 psi
Checked catlitac for blockage
Opened valve cover to check no problems
I just dont get it. I am going to check coils and pim tommorw but do not think it is the problem. Wish at this point i could just drop a weber on it but dont think its possible.
Any and all help is much appreciated. All things listed was done after the problem except fuel pump. No codes read either.
hopeful for replies.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 5:20pm
This sounds kinda dumb and basic, but I have seen professional mechanics make mistakes on plug wire locations.  I don't have the info handy, but maybe someone with a running normally Duke Fiero can post up where they have their wires.   I had an 88 Duke for a few months, and quickly found out there was a public confusion on which plug connected to which post on the coil packs.
This is the photo I went by and found it confusing back then as the Coil Packs lugs are not in a straight line.
Post Options Post Options   Quote Chris38 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 5:52pm
Dont think it was a possibility. I done one at a time and car was running good with the ones on it before problems started. But i will most definitely recheck.
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 6:51am
Hi an Welcome
I have an 88 Duke with the Coil pack,the Thing? That sets your Ing timing is a sensor that bolts in the side of the block an can give you trubble some times,looks like an over grown led pensal an can crack.all so the TBI injector can gum up,still lets some fuel in but not the right amount an make the motor run lean or Ritch,it messes with the computer,there are other members here that may have better in put than me,The TBI has a small screen in it,one Screw holds it in, check that,carefully there's O rings in there that go hard an can leek,should replace them,good luck hope this helps
Post Options Post Options   Quote beken Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 1:17pm
It sounds like your car is starving for fuel.  Have you replaced your fuel filter?  I've changed mine every 5 or so years.   On a Duke engine, I think it sits right on top.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2016 at 6:23am
On the '87 it was moved down below where the V6's is.
Get a scan tool, and see what your MAP is reading (you need to know what the voltage vs MAP is).
Might be dying when a load gets imposed, and the vacuum drops.
