  New Posts New Posts RSS Feed - oil in the intake 2.8 v6 looks fresh
swashburn View Drop Down
Post Options Post Options   Quote swashburn Quote  Post ReplyReply Direct Link To This Post Topic: oil in the intake 2.8 v6 looks fresh
    Posted: 23 December 2008 at 5:17pm
I took the egr pipe off anf found oil residue on it. Why would there be oil in the intake ? sounds like the motor pressure must be way to high?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2008 at 6:25pm
If you have blow buy you can get oil in the intake, a little oil is normal as the PCV and Valve cover breather allow oil vapor into the intake.  The oil in the intake is one reason I delete the pipe from the rear valve cover to the intake tube and replace it with a small K&N Filter in the valve cover then cork off the end at the intake tube.
