3.4 DOHC
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=1047
Printed Date: 23 April 2025 at 5:28pm
Topic: 3.4 DOHC
Posted By: Kyng_72
Subject: 3.4 DOHC
Date Posted: 08 December 2008 at 1:38am
I just found what I consider a killer deal on a 3.4 DOHC. I am trying to decide whether I should switch from the 2.5 Duke to the 3.4 DOHC, so I have a few questions. My car is an 88 coupe just incase this helps to get correct info.
1. Will I need to track down a V6 engine cradle or can I just as easily use the 4cyl cradle. (Which I think I have to.)
2. Can I use the Stock Exhaust Manifolds or do I have to look for headers. (might update to headers at a later date if I can run with the manifolds)
3. Has anyone in the club done this conversion?
Date Posted: 08 December 2008 at 2:23am
Ok I hope you realize that NOTHING from your 2.8 can be used on a 3.4 TDC motor.  I think you can use the exhaust manifolds from the 3.4 TDC and modify it to work with the Fiero exhaust system.
The 3.4 TDC motor is probably my favorite engine transplant, if it was not such a huge PITA to do I would do one myself.  That 7000rpm redline and simply exotic sound is what turns me on with that setup.  As for cradle you can use your cradle just fine, however it should be removed and re-enforced as the 88 cradle is a really weak cradle. (much weaker than the 84-87 variant)
The Isuzu 5spd in your 88 (assuming you have a 5spd) won't last very long, maybe a year or 2 before it grenades.   The Isuzu on my 4.9 lasted 6 months to a year before I had to change it. Been through 4 of them.
There will be major wiring to do, some metal fab work and welding.  Note the 3.4 TDC wiring is MUCH more complex than any other V6 conversion.  Only ones harder are the 4.6 V8 Northstars and the new 3.6 GM DOHC motors.
        I say if you have time, money and a shop to do it in, DO IT.  You'll love the car.  However if you don't know how to work on cars, don't have access to a welder and know GM EFI wiring you would be better off doing the 3.4 Pushrod motor from the early 90's Camaro.  Its pretty much a bolt in for your car, and if you find a complete Fiero V6 wiring harness its all plug and play.  The engine has the same mounts as the 2.8 and can use all the 2.8 fuel injection.  So you swap on V6 Fiero wiring and sensors, plug it into a Fiero V6 ECM and drive away.   Its not nearly as fast as a 3.4 TDC, but its a HUGE upgrade from a duke.
Posted By: Kyng_72
Date Posted: 08 December 2008 at 2:48am
Well considering that I currently have a 2.5 4 cyl not the 2.8 V6 I am quite aware that no engine component can be used in the swap. The big question is, would it be easier to use a V6 cradle instead of the 4 cyl cradle?(if so does anyone have a line on a 88 V6 cradle?) I do believe I have the Getrag 5 spd trans (is that the same as the Isuzu 5 spd?)
I am just considering this as I can get the 3.4 TDC for what I consider really cheap and this will be a winter/spring project anyways so the time and money will be spread over a few months.
I do plan on reinforcing the cradle in any case.
Date Posted: 08 December 2008 at 2:54am
Sorry I have been up for nearly 24hrs and glazed over the part about the 4cyl.
Ok the V6 and 4cyl cradles are the same.  There is no difference in them.
The Isuzu 5spd is what was used on all 4cyl Fieros' from 85-88.  The Getrag 5spdswere on V6 Fiero's from late 86-88.   If both your shift cables come over the trans and have one mounting bracket for the 2 cables its an Isuzu.  If one comes from under the trans and goes up, while the other goes over the trans and comes down, then it is a Getrag.  I think I have a pic of my Getrag in my 88 and my Isuzu in my 85.  If I can find them quickly I'll post them up.  If not I'll go and snap a few shots in the Morning and post them up for you.  One sorta way to tell, all the Getrags had a Dipstick for the Trans, where 75% of the Isuzu's did not.  You had to pull the VSS to check the fluid level.
Date Posted: 08 December 2008 at 2:58am
Getrag Cables,
Date Posted: 08 December 2008 at 3:00am
Isuzu Cables, not they run side by side and go over everything and then down to the trans.
Posted By: Kyng_72
Date Posted: 08 December 2008 at 3:07am
Getrag Cables,
http://members.shaw.ca/davidbergquist/87GTcables/4.JPG/img - [img]http://members.shaw.ca/davidbergquist/87GTcables/4.JPG[/img ]
I get "PAGE NOT FOUND The web page you are trying to access doesn't exist on members.shaw.ca" thanx anyways
Dave might I suggest you getting some sleep before the sun comes up
Date Posted: 08 December 2008 at 3:24am
Ah Frack, I had a big reply written, hit the wrong button and lost it all.
Ok Short reply.
Link is fixed, I screwed up the markup tag.
Should load fine now.
          You know who I am? But for the life of me I can't remember who you are? I don't recognize the nic.
        Drop me a PM to jog my brain. I think it needs a jump start at the moment, and maybe a shot of nitrous down the throat to get it fired up.     Well I'll talk to ya all in the morning.
Posted By: Kyng_72
Date Posted: 08 December 2008 at 3:29am
I am thinking of engine mounts when it comes to what engine cradle to use as I am sure the 2.8 V6 has different engine mounts than the 2.5 4 cyl
Date Posted: 08 December 2008 at 7:18am
In a nutshell - everything has to be fabricated.
The engine/tranny combo has to sit very low on the cradle, or the massive heads/valve covers wont clear. I did the harness and assisted on the install in another guys car about a year ago.  It's tight.
The OBD1 versions (up to 93) are not as good an engine, but - the install of them is WAY (!) easier.
Date Posted: 08 December 2008 at 9:30am
The 4cyl and 6cyl use the same mount points on the cradle.  As there are 3 lower mounts on a Fiero engine tranny.   2 Mounts from the Transaxle to the cradle, and one lower front engine mount.   All cradles have the same mount system for V6 and 4cyl.   The only change is the bracket that comes off the motor.  I don't know how to explain it any better.   The cradle is the same regardless if you have a 4 or a 6.   However as Dr. Fiero said.  Its a bitch of an install if you don't know how to weld and fab up parts.
Posted By: Buddy
Date Posted: 09 December 2008 at 12:15am
Why are we not talking 4.9 here?
Posted By: Kyng_72
Date Posted: 09 December 2008 at 1:40am
well mostly I want the exotic sound and looks of a DOHC and I was told that the hardest conversion is the 4.6 northstar and I found a killer deal for a 3.4 DOHC and I can't find a quad 4
Posted By: Buddy
Date Posted: 09 December 2008 at 6:36pm
I think you might be confusing engine families. The 4.6 Northstar IS one of the most difficult swaps while the 4.9 (totally different engine) is regarded as one of the easiest, cheapest and best bang for the buck swaps out there. Just ask El Capitan...
Posted By: Kyng_72
Date Posted: 09 December 2008 at 8:38pm
I am not confusing engine families just stateing my twin cam/dohc choices my first choice would be a 4.6 Northstar V8 or 3.5 Shortstar V6, then the 3.4 Twin Cam V6 or the 2.3/2.4 Twin Cam 4 cyl. The 4.5/4.9 doesn't really grab me maybe if I were to see and hear it in person.
Posted By: Oceanwave
Date Posted: 07 February 2009 at 6:46pm
I just happened upon a 3.4 DOHC complete but beat at a quirky little shop next to LORDCO on Edmonds in Bby. It's all there except the Alternator & ECM guy wanted $200.00 Won't vouch for the shop or motor but I just knew it would fit...
I'll race anything with wheels!
Date Posted: 07 February 2009 at 7:27pm
There is a 3.4 TDC 1997 Monte for sale on Craigslist right now, complete car. Totalled from accident.  $250 running.
