Major problem.
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2970
Printed Date: 22 November 2024 at 7:32pm
Topic: Major problem.
Posted By: 87FieroSE
Subject: Major problem.
Date Posted: 29 June 2012 at 8:55pm
So, main issues to address:
1.) My temp gauge rose to 260 and sat there forever, saw
smoke coming out of my Thermo housing. Tightened it and
ran it back home, hitting between 240-260 and dropping
then rising.
Replaced the Coolant temp sensor earlier, stayed around
120-220 but then I drove 5 minutes down the street, thick
white smoke coming from my bay, stopped and it was now
coming out of the head/under the valve cover.
Bought a new water pump, thermostat to install tomorrow.
2.) Was told it might be a valve gasket leak, or not
enough coolant.
So tomorrow I'm doing an oil change, cooling system
flush, gasket change (If I can get the EGR off... the
bolts are rusted to all hell),
But white smoke coming from under the valve/behind the
valve cover? Thinking it's not enough coolant in the
engine, what do you all think?
Date Posted: 30 June 2012 at 8:04am
Sounds like serious engine problems to me. White smoke coming from
there is excessive blow-by, which is typical of a worn out engine. Could
be bad rings or just worn out cylinders.
Have you done a compression test yet?
That is where I would start before spending a whole bunch of money
replacing stuff for nothing.
Date Posted: 30 June 2012 at 1:13pm
Hey Dawg.
Good news/bad news.
The good news is that what sounded to you like serious
problems were minor, replaced the T-stat, flushed my
cooling system, oil change and now I stay at the first tick
on the gauge.
Bad news: Leaking cooling all over my engine from the upper
hose, time to replace that
Date Posted: 30 June 2012 at 8:42pm
What about the white smoke?
Date Posted: 03 July 2012 at 7:58pm
It was VERY low coolant.
Solved by flushing the system, burping and filling it back
up.
Next step, I still have a leak in my upper hose connecting
to my Thermostat housing, need to either get a new hose
(Ordered already) or try to see if a new clamp will fix the
problem.
I'd rather just replace the hose, but how hard is it to put
a new one in? Space is really limited, any tips?
