  New Posts New Posts RSS Feed - Squealing sound when car turns on!
InfernoFiero View Drop Down
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Topic: Squealing sound when car turns on!
    Posted: 19 July 2011 at 1:26am
Hello,
The Fiero squeals which may last just a few seconds when I
turn on the car. I notice the sound comes from the back of
the car...
Is this a waterpump issue?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2011 at 8:11am
Sounds like a loose or worn belt.
What was the final outcome with your coolant issue and with your leaky sunroof?
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2011 at 8:35am
Patty is spot on. It is a belt due to some cause or another, and if you were leaking coolant in that area, that seems like the most probable culprit.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 12:43am
Hello,
I finally fixed the leaks by drilling the holes in each
of the sunroof drains, but just much more clearly so no
rubber was in the way. I put the comment in that post so
if my page ever pops up in GOOGLE it give some sort of
hope to the person viewing it.
That being said, I have not been able to do the coolant
burping yet, as I have been far too busy! I will do it
this weekend for sure (oh wait, I'm working then too)!
Anyways, I am extremely confused when you both say that
the belt could be the issue. I bought the Fiero under the
impression that there was NO belt. That's what the seller
told me, and being skeptical I researched this online.
This website says
there is no belt or chain!
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 12:49am
Originally posted by InfernoFiero InfernoFiero wrote:
Anyways, I am extremely confused when you both say that the belt could be the issue. I bought the Fiero under the impression that there was NO belt. That's what the seller told me, and being skeptical I researched this online...
I'm honestly beginning to suspect that you're just trying to yank our chains.
You're telling us that when you look at your engine you can see NO belt on it?
It's no wonder then you have overheating (and no doubt charging) issues!
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 12:58am
No, I am being completely genuine with my shock. I was
under the impression that it was gears to gears as
explained in the link as opposed to having a belt! At first
I was skeptical though, because a car without any
belt/chain was a first for me. I didn't look to notice any
belt, but I guess we have a belt then!!! AHHHHHHHH!
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 1:01am
No one here has made any reference to a timing belt.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 1:08am
I thought you guys were talking about the timing belt. My
bad. Tomorrow I'll try to find the belt you guys are
talking about. I thought there was only one belt for cars
and that being the timing belt . What does this belt you
guys are referring to do?
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 1:15am
What does this belt you guys are referring to do?
Have a look at your engine and you tell us. Seriously. Consider this a little test to see how genuine you are in your desire to work on a car.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 8:40am
Aw Patty, at least throw him a bone. The belt is located on the "nose" of the crankshaft, far over to the passenger side.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 2:44pm
I appreciate your help guys, thanks!
karnak View Drop Down
Post Options Post Options   Quote karnak Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2011 at 10:39pm
If you do find the belt then you can check it to see if it is tight but not
too tight (motor off). Espically if it is a v belt . If you over tighten it it
via the alternator bracket, then the belt might not squeak but the
tension you apply may either damage the belt or hurt the alternator
or water pump. A water pump or alternator that is starting to fail can
lead to squeaking also but would likely be more constant. Rain that
comes thru the vent can make the belt squeak. I recomend a shot of
belt dressing on it first (comes in an aerosol can) is a reasonable
starting point
If it is not a v belt and is a serpentine belt then replace it
Gary
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2011 at 5:13pm
Hello,
I ended up buying belt dressing like suggested by karnak
and left the car on and sprayed it at the same spot for a
few seconds. No squeaks ever since!
Thank you guys for help!
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2011 at 3:46pm
The belt is squealing again, so I will now replace the
belt. If the squealing returns, I guess I will have to
replace the belt pulleys as I do see some rust on them.
Colby View Drop Down
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2011 at 4:35pm
Have you adjusted the tension on the belt yet? You may want to try that first before replacing it.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2011 at 5:59pm
I'm a little worried that I might over-tighten the tension!
Am I supposed adjust the tension to the point where there
should be no more than 1/2" of deflection when pressure is
applied with your thumb?
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2011 at 11:46pm
Don't worry too much about it. I'd guess that it would take quite a bit of pressure before anything bad came from it. Just start off by making it a little bit tighter, then if it still squeaks, do a little bit more, etc.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2011 at 9:14am
Yes, the easiest way is as Colby says. Just snug it up, start it, listen, and tighten it little by little until you find the right tension. And the half an inch deflection is typically accurate if you want to try and go that route too.
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 6:07pm
Alright thanks, and is the only difference for the
accessory belt for a Fiero with A/C just be a bit longer in
length than the belt for a non A/C Fiero?
Edit: Nevermind, they are the same length.
I managed to replace the belt, and my car isn't squeaking
anymore, and I feel a significant difference in power. My
acceleration is much more quicker, and my rpm at start up
doesn't go higher than 1.5 (usually was around 2)!
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2011 at 9:03pm
Hm. 1.5 is still rather high, it should be down around 1-1.2
