  New Posts New Posts RSS Feed - steering wheel shake when braking
mxracer208 View Drop Down
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Topic: steering wheel shake when braking
    Posted: 28 August 2012 at 9:51am
I have an 86 GT and when I hit the brakes, the pedal alternates in feeling
from good pressure to low. Also, the steering wheel shakes and there is a
bad rattle. My rotors dont feel warped and I just got a 4 wheel alignment.
Any help would be great
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2012 at 10:09am
Bad rotor. Replace both front rotors.
You can't tell by eye. The warpage is way too small to see.
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2012 at 10:39am
okay thanks. however, I did replace both front rotors last year due to the
same problem... its only been roughly 5000kms since replacing. Does that
mean that there is something wrong in the caliper or am I buying the worst
quality rotors?
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2012 at 8:20pm
It is possible that the rotors are cheap and warping easily. But most
likely it's your crazy driving....:)
Those stock brakes can only handle so much heat. Sounds like you
need to go Grand AM conversion on the fronts.
Once you do it, the parts are cheaper anyway.
Post Options Post Options   Quote mxracer208 Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2012 at 11:23pm
thanks for the help. I'm not sure how much longer I will be keeping the car
so i dont think i will be doing a grand-am conversion
