Loosing coolant somewhere... |
kawana
Senior Member Joined: 09 June 2007 Location: Canada Status: Offline Points: 508 |
Topic: Loosing coolant somewhere... Posted: 30 November 2008 at 10:27am |
Well i was changing my headlight bulbs today, and i happened to glance at the coolant resevoir. Well wouldn't you know it, its almost empty! If you remember, i just changed my heatercore not 2 weeks ago, at which time i burped the system, as per Capt's tutorial (i think it was capt's anyways), and topped the res off to the FULL mark. I have no idea where it would be leaking from, as i park in the driveway, and its been wet all week. I already checked the hose connections going to the heater core, and they are dry/dont look like coolant has been leaking out there. Where else should i check?
Post Options Quote Reply Posted: 30 November 2008 at 12:35pm |
Refill it again, and drive it for another week. See if the level changes. There might have been a few small pockets of air working there way out. Plus what percent antifreeze did you put in. It can evaporate if you used plain water.
kawana
Post Options Quote Reply Posted: 30 November 2008 at 1:44pm |
im not sure actually, i used a premixed coolant, in a yellow jug. Its a pretty common one, so im sure you know which one im talking about. Ill top it up and see what it does.
