Interior fan not working. |
Author | ||||||
![]() ![]() ![]() ![]() Posted: 27 November 2009 at 9:15pm |
My fan which runs the heater has stopped functioning. I have yet to check the fuse (As I just got back for a couple days) but apart from that, is there any known issues with it?
If it doesn't work on ANY speed - check the fuse. If nothing, then apply +12 straight to the single wire connector on the motor. If that works (only with straight power), get back to me.
If it only works on high - your blower resistor is probably gone. |
Clean the mouse nest out of it.
Just a heads up, I got a call from Romeo, he did not have a chance to do any real testing as he had to take a trip to Mexico for a wedding. However he thanks all the suggestions.
Mexico, eh? If I was working as border patrol, I'd be a checking his rocker panels.
wayneh70 ![]() Member ![]() ![]() Joined: 09 May 2009 Location: Canada Status: Offline Points: 52 |
I had this exact problem, fuse was fine - turned out that one of the wires on the blower motor was off, replaced it and HEAT!
Gotta love the simple solutions :) |
SAME HERE! Wow, same car, same problems. lol
