  New Posts New Posts RSS Feed - Cradle bushings (poly)
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Topic: Cradle bushings (poly)
    Posted: 13 January 2010 at 10:41am
Does anyone have a set of these I could 'borrow' until the fiero store order comes in?
A black set would take preference, but red will be OK.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2010 at 9:21pm
John I sure would like to see your poly bushings when they get here.  I need to take some measurments off them.
Could we do that?
Damien
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2010 at 9:27pm
Yup.  With luck they'll be here tomorrow, later in the day.
I'm slapping them in pretty fast though, so you'd have to head over shortly after I call you.
marcelvdgn View Drop Down
Post Options Post Options   Quote marcelvdgn Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2010 at 11:10pm
Hey
if you guys are looking for polyurethane blanks to machine your own, let me know and ill price the blanks for you.
let me knoe your od and id dimensions
i can get 12" and 24" lengths in any durometer
Marcel
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2010 at 11:29pm
Hmm raw raw round stock.  Hmm, poly replacement ones are stepped and would require the bushing itself and then a "cap" to go one the other side so there is no left to right slip. I know the ones Dawg is going to make will be aluminum or steel.  Personally I think steel would be better and cheap to buy stock, but more expensive in the tooling time.  Hmm Stainless, Na that would be too expensive all around!!
           Marcel what is the material you can get?  Anyone able to get Derlin?   I think if we went with Derlin would could even get Micheal (sp) to turn them out on the lath, ooh ooh, that is an awesome idea.  LOL, Na I think Dawgs CNC would be faster and more accurate.
Just as a side note that everyone knows, the 88s were factory solid mounted with steel, so there should not be any concern with how hard we go with the mounts.
Post Options Post Options   Quote marcelvdgn Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 12:03am
I stock a variety of extruded materials in round stock up to 4" diameter
Nylon, Moly filled Nylon, Delrin in black and white,
UHMW PE up to 8" diameter,
However we sell most in 8' lengths
But if you tell me what your thinking about ill search around for you
Poly ureathane is a cast material so the lengths are shorter
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 9:35pm
OK...Please call as soon as you get them and I'll drop what I'm doing.
I've been doing some building maintenance for a couple hotels in Vancouver lately.  So I might be an hour or so away.
Do I need to PM my phone number?  If you don't have it anymore Dave does.
Thanks
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 9:40pm
Can we be friends?.....:)
I'll have more information after taking measurements.
Thanks,
Post Options Post Options   Quote marcelvdgn Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2010 at 12:50am
Ive been away
sorry for the delayed response
Let me know what your after
Marcel
