  New Posts New Posts RSS Feed - engine problem plz help me
Guests View Drop Down
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: engine problem plz help me
    Posted: 01 May 2007 at 7:49pm
hey guys my cuzins havin a problem with his engine it seems to be runnin very slugesh almost lik its lackin power or not sukin enough air and it its also spittin black stuff or and dust out the tail pipes and then idle drops low and goes up sometimes and the car tunrs off randomly. plz help
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2007 at 10:29pm
First question, what motor is it?  Heck is it even a Fiero?  Your not goign to get much help without asking questions with at least some details.
Be like me saying what colour is my hair?  Without you ever seeing what I look like.
Guest
Guest
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2007 at 10:30pm
its a 1987 pontiac fiero gt fastback , v6 2.8L
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2007 at 10:37pm
Well spitting black from a 2.8 is an over fuel issue.
First thing to check is coil and a tune up.
Next up is check for a bad O2 sensor, the best way to do that is to check with a scan tool.  However you are over there and I am over here, so I can't help with my scan tool.
I would give the car a good tune up and see if that helps.
Overfuel is caused by too much gas or not enough spark.
The O2 sensor controls how much fuel and the Coil, Pickup Coil, Ignition Module control the spark.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2007 at 6:25am
Replace the air filter.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2007 at 6:36pm
So were you ever able to fix it.
