  New Posts New Posts RSS Feed - Rack up another "win" for the good guys.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Topic: Rack up another "win" for the good guys.
    Posted: 30 June 2010 at 3:23pm
(uhhh, that'd be US vs. THEM)
Yay us!
(but in this case...  me!)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 3:35pm
Lets see if I can guess.
EGR Delete chip plus newer cat.  Plus an oddly effective ignition system, maybe 12 degree's of timing.  Those readings are close to what my 88GT did.
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 5:17pm
Wow, that cat is more like a lion (PUN). 0% Carbon Monoxide... That's nuts.
D_sensitized View Drop Down
Post Options Post Options   Quote D_sensitized Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 6:19pm
A coworker of mine who usually knows what hes talking about, says aircares contract expires in 2011 and its very unlikely they will renew it.
Meaning no more needing to pass emissions tests
But he also says there's a possibility that they will bring in safety inspections as we are the only province without them.
Anyone else heard this?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 7:09pm
I have not heard that, However it IS what I also believe.  They will ditch Aircare and bring in safety inspections.  Cracking down on modded cars, lowered cars, and anything they don't like.   Maybe even going as far as requiring special inspections or special permits for modified cars.  In Europe I have heard that even to put larger wheels on your car, requires special permits.  (informed by Yellowstone on PFF who lives there with a modded Fiero)
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 7:13pm
Yeah, same goes for Australia. Any wheel 1" taller, or wider, than stock requires a special permit for it to be road-legal (Obviously it doesn't matter if it's a dedicated off-road vehicle though). They will hopefully do it the same way as it was in Saskatchewan, which is basically just to ensure the vehicle is safe (Frame, body panels, tires, etc) which lets any well done mods pass easily (Johnny Boy's car would be just fine, for example, because the wheels still fit within the body work). Basically, imagine what we have no as an out-of-province vehicle inspection, but done semi-annually.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 7:14pm
This was my Caddy 4.9
and this was my 88GT I can't find the good report with the new cat, this was with the OEM cat that was about to fail and the slightly leaky stock injectors.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 7:17pm
Which means John you would have failed the test if you were an 88 due to Nox readings.  Granted you would have passed the NASTY stringent CO test.  (your car is allowed 4.32 and 88 is only allowed 0.85)
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 10:05pm
In a nutshell....
Engine is virtually new.  Might have 10-15K km's on it.
New injectors.
New cat.
EGR is there (ummmm...  I think...  too many cars).
Mild cam.
Can't remember when I set the timing last - Looks like maybe I bumped it way up (explains the high nox, and low 'other' readings!).
