Forum Home Forum Home » Buy / Sell » Everything Else Wtd or FS
  New Posts New Posts RSS Feed - FS: Lots of Fiero parts!
 Post Reply Post Reply Page  123>
Caladin View Drop Down
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Topic: FS: Lots of Fiero parts!
    Posted: 06 February 2011 at 7:47pm
Updated Jan 4, '14
Everything listed plus more is FREE to a good home! The only catch is that you must take everything!
All items are for local pickup in Abbotsford only. Send me a PM should you see anything that your interested in.
Engine / Cooling:
87 2.5L Radiator - $15
87 2.5L Radiator Fan - $15
- New coolant temp sensor - $10
- 87 2.5L Coolant tubes (Non AC - Manual trans) - $30
- 87 2.5L Delco Alternator - $15
84-88 2.5L Dog bone (New rubber bushings) - $15
87-88 2.5L Intake - $15
Coolant surge tank -$5
Heater Core (Non AC - Few years old) - $10
Heater Core hoses - $5 (New)
Body Parts:
- GT quarter panels (in primmer) - $15 each
- GT Fenders (painted yellow - aftermarket signal) - $35 for the pair
- Red front hood (sanded down - good shape - has sat outside 2 years) - $20
- GT right rear wheel well liner - $5
- Power mirror & standard mirror set - $offer
- Mirror gaskets - L+R(Fierostore - New) - $5
- Full set of rounded belt line trim (available in pieces - will require painting) - $ offer per piece needed
- Headlight door bumpers (Fierostore - New) - $4
- Rear quarter panel molding clips (Fierostore - New) - $10 for the pair
Interior Parts:
- Leather Camaro steering wheel with Fiero GT center horn button - $25
- Fiero Illuminated flush mount stereo plate - $40
- 84 Fiero Shifter (shorter) - $10
- Leather shift knobs  $10
- Tan passenger seat from '85 - Excellent shape - $20
- Dash - Best shape dash I have ever seen.  Corners are undamaged! It did have small damage repaired to the top.  I repainted it 2 tone factory grey/black. - $50
This photo shows the alarm led that is installed in the front center of the dash.  It's not that visible when installed in the car.  But very visible when the alarm is armed.  You can also see the repaired spot.
- GT center rally gauge pod (Black - with wiring) - $30
- Center HVAC surround (Black - sold seprate from GT guage pod) - $20
- '85 Center console - $10
Console skeleton - One larger crack (3rd photo) that can be repaired and a few smaller ones that do not go through. Overall it's in much better shape then average. - $10
- 4x10 160W Kenwood speakers (Used) - $20
- Kenwood KDC-MP8017 MP3 deck & remote (2001) - $20
- Many other interior trim pieces available!!
More Misc Parts:
- OEM Swaybar with Polly bushings and end links (New)(Control arms in picture no longer available) - $15
- Steel clutch pedal with upper bushings - $15
- 84-87 OEM radiator cross-member support braces (excellent shape - Painted with POR15) - $15
- Spare tire on steel rim - $10
- HVAC Blower motor - $5
- Variable speed wiper motor - $15
- 5 Speed shifter $15
- Parking brake lever/switch - $15
- Hood support - $5
- OEM Under hood jack - $5
- 84-87 2.5L Dash guages and housing - $20
- 84-87 Brake Booster - $10
- 84-87 Tilt steering column (complete with new lock) $30
Clutch master cylinder (87 2.5L - 2nd design) - $15
Clutch slave cylinder (Watson brand - cast iron) - $15
Lots more parts available. Here are some pictures to give an idea of what is available.
 IMG_0565.jpg">Only the tan seat is left.
Edited by Caladin
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2011 at 8:20pm
PM sent. Dibs on the rear strut camber bolts.
Shakey Dave View Drop Down
Post Options Post Options   Quote Shakey Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 4:22pm
If the gray Fiero seat (great shape with speaker cut outs) is still available, I will buy it for the $40 you are asking.
"Shakey" Dave Hathaway
(604) 984-7897
www3.telus.net/myhistory
wheelin_phil View Drop Down
Post Options Post Options   Quote wheelin_phil Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2011 at 9:14pm
Hi new member here from kamloops. I need the lower casting in a tilt steering column would happpen to have one ?
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2011 at 10:29pm
PM sent
waylon View Drop Down
The Stereo and Alarm Guy
Post Options Post Options   Quote waylon Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2011 at 5:06pm
i need headliner and door panels .....
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2011 at 2:26pm
PM sent
fiero052 View Drop Down
Post Options Post Options   Quote fiero052 Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2011 at 11:28am
i would be interested in the plug wires, throttle body complete with injector, and the ignition module and coils.
will send PM
Glenn
Glenn
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2011 at 9:59pm
PM being sent for the
 - Front upper/lower control arms - painted, polly bushings, with new Moog ball joints. Never used - $ offer
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2011 at 8:47pm
Bump. Stripping the car down over the next 2 days.  Added many pictures and parts today.
Anyone need an engine/tranny or frame??? 87 2.5L 5spd
Still have FREE base model door skins / fenders / '85 rear bumper available as well.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2011 at 7:51am
I am looking for the seat belt plastic covers, the lower ones for passenger side and and a few other trim pieces, looks like you have the same gray as I do...let me know:)
mapleleafr View Drop Down
Post Options Post Options   Quote mapleleafr Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2011 at 4:42pm
Would you happen to have the accelerator / throttle cable. I have 1986 Fiero SE with a 2.8 liter engine. I have pulled the cable and it is exactly 8 feet long.
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2011 at 4:50pm
Sorry, I do not have a throttle cable that will work for you.  The 2.5 and 2.8 use different cables.
smitty70 View Drop Down
Post Options Post Options   Quote smitty70 Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2011 at 3:57am
Do you still have the -- drivers side rear gt quarter panel? $40?
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2011 at 12:29pm
Yes - PM sent
Post Options Post Options   Quote waylon Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2011 at 11:33am
i just messaged your phone number . sorry for delay . i will get headliner and sunrood weather strip off you if you still have it
Rob N. View Drop Down
Post Options Post Options   Quote Rob N. Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2011 at 10:30am
hi, are the New coolant tube brackets - $20 still available?
Rob
Post Options Post Options   Quote Caladin Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2011 at 10:57am
Rob
PM sent
Post Options Post Options   Quote waylon Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2011 at 4:06pm
Linlor View Drop Down
Post Options Post Options   Quote Linlor Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2011 at 7:33pm
Are the poly bushings still available front and back? I'll take what u
have. You can email me as well in case I don't get back on here. I
will most likely be coming over to the mainland on Sunday this
weekend or next weekend.
Thanks
Don
Don_ostergard at shaw dot ca
Ferrari 308 Replica
Prova 5000s Countach Replica
