Tech Session Saturday April 21st My House |
Topic: Tech Session Saturday April 21st My House Posted: 20 April 2012 at 11:34pm |
This will be at my house 16908 104th Ave. Surrey B.C. Start time is 10am and will run until dusk or it starts to rain, whichever comes first. Food is bring your own, there is a Subway a Quizno’s and a Tim Horton’s 10 blocks from here, or a deli / pub 1 block from here, as well as a Corner Store with a hot case across the street. I was planning on doing the clutch on my 88GT however have decided to put that off in favor of removing the front timing cover on the V8 and replacing the gaskets between the block and the cover and the cover and the water pump. Just in case that was the source of the water in the oil and not a blown head gasket. David. Sorry about the lateness of this post I was planning on doing it earlier today once we had a better feeling of the weather however had to take Arianna to the hospital. (She’s fine, just a nasty cut on her head) |
Post Options Quote Reply Posted: 22 April 2012 at 12:44am |
Had a great time at the tech session.
Tried to mount my idler pulley but the belt I have is just a little too short. Nice to see everyone on such a nice day. Cheers. Dawg |
Post Options Quote Reply Posted: 22 April 2012 at 11:11pm |
Yes it was a great day. Danny got his front brakes done, and a new belt installed. Tim got his coil swapped. Rob did a lot of tweaking and work, but in the end I don't think anything got sorted out. We were able to find out what parts are working, but not the root cause of a trunk that won't pop. Tim got his coil swapped around so its not just laying on top of the bad coil. I had great intentions of tearing down my V8 until my compressor blew a unique fitting that will have to be either made by someone or brought in mail order from the manufacturer. (Briggs and Stratton Compressor)
David new member came over with his 87GT later in the evening and we were tracking down a lack of power. Found his timing was set at Zero degree's maybe even 2 degrees ATDC so we moved that up to 14 degrees BTDC. Which totally changed the cars handling. On the test drive he mentioned his gas gauge did not work, as I was questioning a noisy howl from the car. He said it has lots of gas in it, he's only gone 250kms since his last fill up. At this point my eyes popped out of my head and spun the car around for the gas station. It took 39 liters to fill it up. I then explained that with spirited driving 200 was about the max to expect in town. His tach also reads high, his temperature gauge is totally whacked out reading into the red when in fact the car is at 180F as measured by both a scan tool and my laser thermal meter. Car is in REALLY good shape interior is nice, just needs some electrical gremlins sorted out. Previous owner replaced the motor, which runs nice, BUT did dumb things like put the heads on backwards, which located the sender for the temp gauge over near the battery. So instead of moving the sender they cut the wires and ran them over to the other corner of the block. Also wiring is in the wrong places (routed wrong for other major things) So with some TLC this car could be a show winner, once an experienced Fiero mechanic spends some time with it.
Did anyone else but me manage to get a heck of a sunburn? I am so torched today that my face feels like its on fire. |
Post Options Quote Reply Posted: 22 April 2012 at 11:30pm |
I got a little bit of sun yes, but after some chores got done I went for a drive later. I love driving my Fiero in the sunshine. Windows rolled down, tunes playing with the wind in my hair. It doesn't get any better than that. Very relaxing.
Dawg |
Post Options Quote Reply Posted: 23 April 2012 at 12:58am |
Oh Man I totally agree with you. Radio up, Windows Down, Top Out. Throttle to the floor grabbing gears. Its actually in many ways better than sex. Same smile, but you don't have to get sweaty or cleaned up afterwords. Plus it can last a lot longer.
The only way a drive like that can get better, is when you are grabbing gears with the sound of a V8 behind you, and you arm the Nitrous with an open stretch of road in front of you. |
