transmission leakage at drain bolt |
Rob N. ![]() Senior Member ![]() ![]() Joined: 02 March 2008 Location: Canada Status: Offline Points: 138 |
![]() ![]() ![]() ![]() Posted: 07 August 2012 at 12:29pm |
Hi, I've changed my fluid in my GT (manual 5 spped) and the drain bolt was realy torqued on. I've re torqued it to the right specs and now I have a slow drip. Is there suppose to be a crush washer ? I' can't see one in the books that i have.
Get some thick gasket material from Lordco and cut yourself a
"washer". No more leak. Dawg |
I was thinking of a soft alumin washer or a copper crush gasket. But I'll try the gasket material first. Just wondering if there was an SB on it ..
karnak ![]() Senior Member ![]() ![]() Joined: 28 August 2009 Location: Canada Status: Offline Points: 349 |
this might help...
aha! I knew it seemed like some thing should be there! Wonder if it's steel or copper?
