  New Posts New Posts RSS Feed - Engine ticking. Lack of power suddenly
redni View Drop Down
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Topic: Engine ticking. Lack of power suddenly
    Posted: 02 April 2013 at 1:23am
So I started my car up after 2 days.. Cold start. All systems go. Sounded
fine. Power was there. Warmed it up for about 2 to 3 Mins.. Then
Idecided to give it a ltitle kick around the block and I get sudden loss of
power and engine sounds high power lawnmowerish... Idles a little ruff.
Not throaty..power jus not there all of a a sudden.. I reset the battery
incase..   I doubt iit's a misfire because I've heard a misfire before on this
car . But who knows. But ya. Happened so fast.. I'm stressing out please
help..
1986 2.8L v6 5spd
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 1:24am
Almost sluggish. And old sounding Just weak tick.. Barely any bak
pressure it seems Iike.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 12:38pm
Clogged cat?
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 2:32pm
I just put. A new one in
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 3:06pm
Muffler. Plugged?
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 3:09pm
Wouldn't make the engine tick. I checked compression. It's150 all
aaround
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 4:17pm
I changed my plugs. I also forgot to mention. It's easier to stall and when
I give it gas it takes forever to speed up. The rpms take so long. It's real
leggy. Sumthing is really off. I just don't know what :(.. Please help guys
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 4:47pm
Plug wires. Which wires are going where? Double-check.
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 4:50pm
Checked all
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 5:16pm
Almost sounds like the timing chain skipped a tooth, seeing it more and more. Try advancing the timing and see if that helps. If that helps, then the chain is most likely going bad you will be lucky to get 5 miles before it jumps again you loose all power.
However a there are a few smaller things to check as well. Make sure you did not blow a fuse for one bank of injectors. If that happens you lose 1/2 your injectors, the car will run rough, but will run.
      Have you checked to see if the cap/rotor are in good shape.
        I would go over all the little things and once you have eliminated all the little things then you will have to look at that timing chain again. Its a pain in the butt job, but with time the average home mechanic can do it.
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 5:59pm
Cap rotor plugs wires all good. New cat. Still same thing. Really rough
idle.. I find that it's easy to stall when I'm driving
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 6:20pm
Well pull the cap off, and put a breaker bar on the crank bolt, its 19mm IIRC, gently turn the crank with the breaker bar until you see the rotor start to move, then turn the crank the opposite direction. they should move in almost perfect unison, more than a few degrees of slop means the timing chain is suspect.
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 7:01pm
Thankyou so much ccaptain. Turned out.. It was my fuse for the fuel
injection.. But it keeps blowing.. Now I was looking into this...
http://www.fiero.nl/forum/Forum2/HTML/124585.html
That's is what I'm. Having now.. I am. Shorting out somewhere but how
could or where could be... Also. I mentioned I have a leak between the.
Inner exhaust manifold and downpipe. Rusted out.. The gasket is gone
from there... Could this be a related issue
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 8:01pm
Well I am glad it was just a fuse for one of the banks. 1st things first unplug the injector harness its a large flat connector near the dogbone mount. Then re-insert the fuse and see if it blows. Obviously you can't start it, but you can try and crank it over. If the fuse does not blow then you need to look at the injector side of the harness. If it does blow then you need to look at the engine side of the harness. There are several places where the injector harness comes in contact with engine mounts and such make sure that it has not rubbed through the insulation.   I had a similar issue where I was blowing a bank fuse on my V8 and turned out it was just bit of the harness had been rubbing, cost me about 20 cents worth of tape to fix it and never had the issue again.   As to the exhaust leak, I doubt it would have anything to do with it, unless it was blowing exhaust gas right onto the harness and the harness is not in that area.
     Again glad it was a simple fix. Now just find the short and away you go.
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2013 at 8:08pm
Awesome. I will check it out. Thanks again!!!
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2013 at 5:34pm
I can't seem to find these locations. Is it possible u can show me a
karnak View Drop Down
Post Options Post Options   Quote karnak Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 4:51pm
Circled
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 4:53pm
Thanks a lot!. I'll check it out
Post Options Post Options   Quote redni Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 4:55pm
Is that the 2.8 v6
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 6:28pm
Yes - it's a 2.8.  That's also MY hand!  I've been recycled!  Well, my photo has been anyhow.  :)
