1984 Fiero failed Aircare |
InfernoFiero
Senior Member Joined: 25 June 2011 Location: Canada Status: Offline Points: 133 |
Topic: 1984 Fiero failed Aircare Posted: 09 May 2013 at 2:52pm |
I took my Fiero to the Aircare center today, and it passed all tests confidently but one: Oxides of Nitrogen (NOx) ppm. The maximum allowable is 2438 and my reading came to be 2714 -- the average passing reading is 712.50. The only thing I did before the Aircare test was I filled up on some Shell gas -- like 5 minutes before -- I always fill it up with Chevron but today was different since I had a quarter tank of gas. I asked around and learned that the major culprit here may be the Catalytic Converter, but I wanted to gather your opinions and guesses on what the problem may be! Thank you! |
Rob N.
Senior Member Joined: 02 March 2008 Location: Canada Status: Offline Points: 138 |
Post Options Quote Reply Posted: 09 May 2013 at 3:20pm |
Try changeing the O2 sensor... fixed my 4 cyl & 6 cyl
Colby
Admin Group Joined: 30 March 2009 Location: Abbotsford/Sask Status: Offline Points: 665 |
Post Options Quote Reply Posted: 09 May 2013 at 5:36pm |
A malfunctioning EGR valve can cause a higher NOx reading.
beken
Post Options Quote Reply Posted: 09 May 2013 at 9:11pm |
It wouldn't be the catalytic converter. My car has never failed on NOx. I'm pretty sure the cat isn't working on my car.
Patrick
Post Options Quote Reply Posted: 09 May 2013 at 11:24pm |
Check your ignition timing. Perhaps it's too far advanced.
