Guranteed2Pass Actually Works!!! |
InfernoFiero
Senior Member Joined: 25 June 2011 Location: Canada Status: Offline Points: 133 |
Topic: Guranteed2Pass Actually Works!!! Posted: 08 October 2013 at 11:26pm |
Just wanted to let you guys in on my little experiment. My Fiero had failed Aircare a while ago due to it's high NOx levels. The only solution I saw to this problem was to replace my catalytic converter, but I decided to give the infamous and inexpensive Guranteed2Pass product a try first -- it's a product that, as titled, will allegedly help you pass emissions test like the Aircare. I read up a lot on it, and found consistently good reviews. I decided to give this product a shot -- it rang up to be 15 dollars at Canadian Tire -- before I went on to replace the catalytic converter. I followed the directions precisely: fill up your car with a full tank of gas, add the product, drive until empty and refill again to full. I didn't even follow these directions quite exactly, but, needless to say, I PASSED the test! I was absolutely surprised! I BARELY passed with my NOx level barely scraping by -- it passed by 20 points -- but I passed nonetheless. This product really made that difference, I was a sceptic at first, but I'm a believer now . Anyways, definitely give this product a try if you ever have issues with passing Aircare! Edited by InfernoFiero |
