Clutch advise please |
Luke
Newbie Joined: 06 May 2008 Location: Canada Status: Offline Points: 11 |
Topic: Clutch advise please Posted: 08 June 2008 at 10:55am |
oK i need some Fiero (86 GT 4spd) advice on my clutch, it seems to stop working. It has progressively gotten worse as in its been hard shifting, which made me think there is air in the line.Which im 99% sure there is but there still is problem still a problem. When the car is running and i try to put it into gear it doesnt grind it just wants to move the car forward. . My question is this, if my clutch has never slipped out of gear and still pulls hard under load, is my clutch fine and its just a hydraulic issue. I tried bleeding the system by myself, but then i was told about the power bleed. a couple mechanics that i talked to, who were somewhat shaddy anyway, told me that there is no way that there is hydraulic problem if there is still fluid in the reservoir. Anyway i just need some quick advice, i dont want replace my clutch obviously. One last question? is the slave in the back. thanks.
Post Options Quote Reply Posted: 08 June 2008 at 4:22pm |
Yes. (short answer) Your clutch itself is really only screwed if it slips, or chatters excessively. If it's simply a release issue (lack thereof) it's hydraulic. Period. Although it's probably not the entire root cause, you could also have bent pedal syndrome. Very common in 84/5/6. See if your free pedal height is about 1-2" higher on the clutch pad than the brake. If they're even close to level, your pedal is bent. Fiero Store has much better designed ones. Other than that... it's still not bled properly. |
