  New Posts New Posts RSS Feed - clutch fluid
clutch fluid
88FormulaFiero View Drop Down
Post Options Post Options   Quote 88FormulaFiero Quote  Post ReplyReply Direct Link To This Post Topic: clutch fluid
    Posted: 06 July 2008 at 10:44pm
Hey all, what type of fluid do you use for the clutch, is it the same as the transmission fluid (GM sychromesh)? its a 87 GT 5speed by the way.
Sorry if this is a stupid question but i cant seem to find the answer in my hanes manual anywhere.
thanks,
Ryan
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2008 at 11:09pm
It uses brake fluid.  Regular old dot 3.  Don't put in Dot 4.  People have used ATF in the past, if your entire clutch hydraulics are shot and you are replacing on replacing everything.  However I repeat don't use DOT4 unless you are replacing everything and converting to DOT4, and don't use ATF unless you are replacing everything soon.  ATF will eventually destroy your clutch hydraulics, and DOT4 won't mix with DOT3, so in short.  Just fill it with DOT3.
