Forum Home Forum Home » Buy / Sell » Engines / Transmissions and Related Parts
  New Posts New Posts RSS Feed - 2.5 problem?
2.5 problem?
chevytruck88 View Drop Down
Post Options Post Options   Quote chevytruck88 Quote  Post ReplyReply Direct Link To This Post Topic: 2.5 problem?
    Posted: 27 September 2008 at 11:58am
84 2.5l auto....idling at 1500-2000 exhaust heats up glowing red hot.... exhaust is good no plugs timing is good.....gotting LOADS of fuel no intake leaks.....any ideas?
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2008 at 12:10pm
Bad IAC or MAP or both.
IAC = Idle Air Control Valve
MAP Manifold Absolute/Atmospheric Pressure
IF the IAC is bad it will cause it to idle high, and also cause the map sensor to lean out the fuel system. The Map sensor plays with timing and can cause the manifold to glow red.
CFoss View Drop Down
Post Options Post Options   Quote CFoss Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2008 at 12:13am
I have one of these engines sitting around.
Lemme know what you want off of it and I'll send them to you for the cost of shipping only. I'm on the island. You may have to wait a bit because I'm in and out of town.
Throttle body and map sensor maybe?
Lemme know.
250 701 3841.
Chay
