TP SENSOR |
Guests ![]() Guest ![]() |
![]() ![]() ![]() ![]() Posted: 09 July 2007 at 4:04pm |
hey i needed to replace my throttle position sensor and i jus dont knwo where it is..... help ? hah
ITs on your Throttle Body. Its the thing with the spring loaded arm that moves with your throttle. Has I think 3 wire plug comming out of it.
do u have n e tips/tricks to changing it?
Uhm it takes 5 mins, or less, you use 1 philips screw driver and remove the 2 screws, then slid it out, install the new one and you are done, just make sure the spring loaded arm is under the Throttle body actuator when you put it in. (or else the TB won't move the TPS arm)
