  New Posts New Posts RSS Feed - 1984 Fiero failed Aircare
InfernoFiero View Drop Down
Post Options Post Options   Quote InfernoFiero Quote  Post ReplyReply Direct Link To This Post Topic: 1984 Fiero failed Aircare
    Posted: 09 May 2013 at 2:52pm
Hello,
I took my Fiero to the Aircare center today, and it passed all tests confidently but one: Oxides of Nitrogen (NOx) ppm. The maximum allowable is 2438 and my reading came to be 2714 -- the average passing reading is 712.50.
The only thing I did before the Aircare test was I filled up on some Shell gas -- like 5 minutes before -- I always fill it up with Chevron but today was different since I had a quarter tank of gas.
I asked around and learned that the major culprit here may be the Catalytic Converter, but I wanted to gather your opinions and guesses on what the problem may be!
Thank you!
Rob N. View Drop Down
Post Options Post Options   Quote Rob N. Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 3:20pm
Try changeing the  O2 sensor... fixed my 4 cyl & 6 cyl
Colby View Drop Down
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 5:36pm
A malfunctioning EGR valve can cause a higher NOx reading.
Post Options Post Options   Quote beken Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 9:11pm
It wouldn't be the catalytic converter.   My car has never failed on NOx.   I'm pretty sure the cat isn't working on my car.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2013 at 11:24pm
Check your ignition timing. Perhaps it's too far advanced.
