  New Posts New Posts RSS Feed - 3400 swap
3400 swap
 Post Reply Post Reply Page  <123
tk_85redgt View Drop Down
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2012 at 2:41pm
Got all the wiring in just have a few more that need to connected and it ran for a few seconds then i turned it off,no fuel likes whick was nice.Thanks to Harrison who did all of the layout for the harness and i put the ends together.Thanks Harrison.
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2012 at 12:58pm
Will got all the wiring done last night with Harrison's help.We tryed to start the car,it would run for a few sceonds then die.today i tryed to atart it again same thing,unpluged the MAF sensor and it ran with a high idle and as sone as i plug the MAF wires back it dies.Also checked for vacuum leaks dont seam to have any.The 3400 ran great till it was pulled so i don't think it's the MAF sensor.
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2012 at 8:45am
Got the car running yesterday had a bad throttle gasket,replace it and it runs good and idles is good also no leaks.Have a few more little thing to do and will be taking it for a ride in a few days i hope.Her is a video of it running.
http://www.youtube.com/watch?v=Nk-uWDlPCsE&feature=youtu .be
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2012 at 12:51pm
Took the fiero out for its first drive around the block a few times,the 3400 sure has more get up and go to the 2.8,the cold air intake sounds great almost like a 4 bbl carb.Have a few things to take care of before go for a good run.Need to do small ajustments on the clutch cable brackets and a pulley needs to be mounted a little better so its not as noisy and it should be good to go.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2012 at 1:28am
Congrats on getting it running, I am sure you are going to have a blast with it.
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2012 at 7:38pm
I hope to,plan on getting a 1 day permit on the weekend going on a good ride.
Post Options Post Options   Quote Dawg Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2012 at 7:54pm
Looks amazing Tino. You and Dad do good work.
See ya in 3 weeks...
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2012 at 11:43am
Went for a drive today drove very nice with no problems.It sure has a lot more get up and go and the clutch is a lot different then the old 1 need to get us to that.the only thing is the speedo works but the odometer doesn't any 1 have a idea why it doesn't.
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2012 at 3:00pm
Heres a video of a short run.
https://www.youtube.com/watch?v=Pes4x-mS3nY
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2013 at 3:45pm
So i bot new MSD coils wires and E3 plugs for the fiero.Put the MSD coils in and started it and went for a ride to make sure it run,then do the plugs and wires.But my new alternator i bot 6 months ago was way over charging  almost 18 volts.So off to lordo and get a  exchange,changed the new alternator and all go 14.74 volts at the gauge and at the battery.know i can do the plugs and wires.Heres a pic of the coils only.
D_sensitized View Drop Down
Post Options Post Options   Quote D_sensitized Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2013 at 3:56pm
Looks good.
Will it make it out to the meeting this weekend?
Post Options Post Options   Quote tk_85redgt Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2013 at 4:49pm
Thats the plan i hope.
