  New Posts New Posts RSS Feed - 88 rear brakes
88 rear brakes
DannyCanuck View Drop Down
Post Options Post Options   Quote DannyCanuck Quote  Post ReplyReply Direct Link To This Post Topic: 88 rear brakes
    Posted: 02 February 2013 at 10:08am
So I have a slight issue in that my drivers rear brake
caliper is going to need replacement soon, (torn dust
boots, missing check valve). The problem is that the
caliper I need no longer exists, neither Lordco or the
FieroStore have them.
This leaves my with two possibilities that I can think of:
1: A bolt on brake swap to more common brake hardware
2: Lose the E-Brake and chuck a front caliper on there.
Which do you guys recommend?
88 duke, bog standard
Colby View Drop Down
Post Options Post Options   Quote Colby Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2013 at 12:07pm
RockAuto still carries '88 rear calipers.
http://www.rockauto.com/
Post Options Post Options   Quote DannyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2013 at 5:02pm
Thanks Colby, That is exactly what I've been looking for
