  New Posts New Posts RSS Feed - Aftermarket Tach Hookup (pic of sub too)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Topic: Aftermarket Tach Hookup (pic of sub too)
    Posted: 26 January 2013 at 11:53pm
Man this was easy. Time consuming but easy.
Pull all the bolts for the cluster to gain easy access to the clear connector on the right hand side.
All 4 wires you need are there. 4 T-Taps and 4 male spade connectors then mount the tach and you are done.
I stole this from PFF.
All the wires you need are on C3- No not all PINK wires are switched power - Yes the Pink Black on pin 5 or pin 9 of C3 are switched power.   The Sub box was thanks to Fire451 the head unit was Fry's Electronics, the Amp was EBay, 4500w, and the sub was Parts Express online. The tach I got from a (believe it or not) A baby swap forum that Lisa is on for 40 bucks and it works perfect.
The box needs to go in another inch, but I am damn near going to need a porta power to push it in. I also need to replace the temporary 7mm screws that I used with some nice black screws as well as put some sort of grill over it.
I also got my new monster tach installed yesterday.
Too bad these parts are only temporary as all of it will be moved into my V8 when its done.
857GT Part 85GT Part 87GT Part Caddy, 93 Eldorado 4.9, 5spd Dual O2 Custom Chip, Custom Exhaust. MSD Everything Now with Nitrous. Capt Fiero --- My Over View Cadero Pics     Yellow 88GT 5spd Full Poly Suspension, Lowered 1/2" in front, Corner Carver.
monzaguy View Drop Down
Post Options Post Options   Quote monzaguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2014 at 7:33pm
nice sub ......BUT.......bad location for those of us with
"long legs
