Anyone up for exhaust manifold job? |
redni ![]() Newbie ![]() ![]() Joined: 02 December 2012 Location: Canada Status: Offline Points: 31 |
![]() ![]() ![]() ![]() Posted: 31 March 2013 at 2:06am |
2.8 v6 1986
Need help. Can't keep going to mechanics that don't know what they are dealing with.. I have ticking sound at acceleration and popping sounds when I let off the Gass... Please help. I will pay. I don't have time or the tools. I'm a student and finals are around the corner for the semester. ASAP would be great. Thanks. Inder 6047631206 |
Not sure if it's the manifold.. Or a leak at the connection where the pipe
to the cat meets.... It's the inner manifold.. Window side |
Hello,
You can try the City Tire shop in Coquitlam. A member from here works there, and I've had a pleasant experience dealing with him regarding my headlight and very awful breaks situation at his other shop. |
It is pretty common to find fire wall side manifolds that are cracked.
When you open the trunk lid after driving in the rain, water lands on this manifold. This cools it off much too quickly. Over time they crack. If you get it out, I can fix it. Dawg |
I think it might b the gasket between the pipe to the manifold???
There should be a fiber donut in there. Try just tightening the two
screws holding it together. Lots of wd-40 first. |
U think that's what is causing the popping sounds and tick? Cuz it looks
like my manifold is fine |
Hey, find a good shop or person and let's offer them two cars as I need mine done also...someone out there had/has manifolds for me to swap with maybe (Tristan)...:)
If it's exhaust related, sure. The cross over pipe is flared to accept the donut. It needs to be squeezed tightly to work.
Dawg |
I think it's y pipe
