Bought a fiero with clutch problems |
Author | |||
Daniel ![]() Newbie ![]() Joined: 12 August 2014 Location: Canada Status: Offline Points: 5 |
![]() ![]() ![]() ![]() Posted: 12 August 2014 at 9:42pm |
Yesterday I purchased a '87 Fiero GT with 117000km. Looked like it was in great shape, everything checked out. Guy said it was a little stiff going into third gear. Test drove it and yeah, it was a little stiff in third but that was it.
Bought it and took it home. On the way home it started making grinding noises into some of the gears. By the time I got it home it got so bad that I knew this would have to be taken care of before I could drive the car. It sounds almost as if someone wasn't pushing the clutch all the way to the floor while trying to shift. I just bled the clutch and it did not fix the problem. What gives? I know nothing about Fieros. With such low km I was hoping for very few problems. |
I am doing the work myself. I made a post on Pennock's forum already about this.Yes, the transmission goes into every gear just fantastic when the engine isn't running.I did not measure it while I was doing that. I will do that tomorrow and report back. Thanks for your help.
Edited by Capt Fiero |
I think it's great... if you're up to the task, and I hope you are. Over the years I've seen so many people on Pennock's give up when the problems start to compound.
Well, that's good news. Looks like you won't have to pull the tranny (unless the clutch disc is worn, but that's a different issue). Nine times out of ten the common problem with Fiero clutches is the slave cylinder sucking in air. Rodney Dickman sells a dual-seal slave for the Fiero that is worth every cent. How high does your clutch pedal sit above the brake pedal? If it sits below the brake pedal, it's bent... or the "banjo" connecting the pedal to the master cylinder is bent and/or worn. Edited by Patrick |
It's sitting exactly one inch above the brake pedal. It's a steel pedal.
So if the push rod extends further than an inch, does that mean the problem is most likely the slave cylinder? I saw quite a few posts about Rodney's slave cylinder and bleeder tool, so I guess I'll get those shipped over here ASAP if it turns out to be the issue. Edited by Daniel |
Excellent.
Keep in mind I'm referring to how far it moves when the clutch pedal is put to the floor, not how far it extends from the slave while just sitting there. If it moves just over an inch when the clutch pedal is depressed, then the hydraulics are probably fine. However, any air in the system will compress and the push-rod won't be moving an inch.
Edited by Patrick |
My 2 cents hope this might help,Few years back I bought one of those
Small inspection cams,Can't tell you guys how valuable one of those Are,Pull a spark plug an just take a peek in,found 2 cracked pistons On my buddy's Moms car-Ford-Mks.And Gear boxes are a no brainier! I use one at work all the time for those tight spots you just can't see.iam sure Ther are around $100 know,good investment guys. Cheers Joe Edited by ARTIC-1 |
Ckid ![]() Newbie ![]() Joined: 03 September 2014 Location: Canada Status: Offline Points: 1 |
I recently was given an 85 GT 4 spd and after about a week of driving I had a catastrophic clutch failure. Talk about a quick initiation to the ins and outs of the Fiero! I replaced the clutch and buttoned it all back up, everything looked good... Until I tried to put it in gear, and it wouldn't go any gear. After a bunch of looking around online I decided I better inspect the clutch pedal as I found the stock aluminum ones were prone to bending. It looked fine, but I decided to remove it anyways just to be sure. Once I had it out I noticed that the master cylinder banjo had worn a groove on its stud on the clutch pedal darn near half way thru. After some carefull welding with the MIG and some filing to reshape the stud the problem was cured! |
karnak ![]() Senior Member ![]() ![]() Joined: 28 August 2009 Location: Canada Status: Offline Points: 349 |
Daniel, where are you located? perhaps one of us can mentor you thru these things as they pop up. the group is located all over the place...
![]() All this info is good but if you have not yet seen a good "part", finding a bad "part" can be a bit elusive. to troubleshoot the slave, a helper is a good idea i like the camera idea.. ebay.. where are you? ![]() |
Daniel is here in Fraser Heights, he and his Dad dropped by here, and I went over to their place. They were doing all the right things, and helped them get the last bit of air out of the slave, and that was when we realized the pressure plate is the problem. Well the pressure plate, or the throwout bearing or the clutch fork, when the clutch is pushed all the way in now, there is a grinding noise when you try to start it. So I showed them the step by step on dropping the cradle. I actually came on here today as I got word from another member that has some parts for them. So Daniel you have got my number. Give me a buzz.
David In case you lost it, 604-584-7717 |
ahh.. excellent! a little of the Capt's guidance and you will be well on your way.
the autocross thread that keeps getting longer is loosely centered over a Fiero that was rescued from a forest. with some elbow grease and a little money, you can have a decent Fiero and really enjoy the drive! There are so many possibilities! Don't be afraid to learn it well. Soon, it will be old hat. Take many pictures as it comes apart. they are going to come in handy later on ![]() |
This thread has been cleaned by me. Patrick is free to post. However I don't want any reference to fighting posted again in this thread. My only hope is that Daniel and his father will see fit to rejoin the group and start posting updates again. They are really nice people, Daniel moved from a Front Wheel Drive Prelude "import car" into a Fiero as he really liked them. He is younger and does not know much about cars but seems to really want to learn. He is actually younger than even Tristan is. (Don't worry Daniel you don't know Tristan yet, but ya will)
They came over to my place a few days ago, with the trans in the trunk of his dad's car along with the clutch and pressure plate. There were fingers physically missing from the pressure plate, and springs in the clutch disk that were either falling out or ready to fall out. The clutch fork itself is in poor shape. Not dead, but very well worn. I told them that they could get by with it, however they are going to order a new clutch fork along with a new clutch disk and pressure plate. They were able to get the car high enough to drop the cradle in there home garage with simple hand tools, by using a guide that I believe they found on the Fiero Store's website. They were also looking at doing either solid or poly cradle bushings, my suggestion was to go with Poly. Solid is better but at 10x the cost of poly and only about 10% improvement over poly, it is just not worth it. I have not heard from them in a few days, but I hope that everything is going well. I suggested they attend tonight's meeting and get to know people on a face to face basis. Lisa and I got tied up with the girls and were not able to attend, but I hope everything went well. There are a lot of really friendly really helpful patient people in the club. |
As with many as stated in this club, without all your help (too many to list) I would not have my car in the condition she is in, or own the car form that matter if it wasn't for the support...moving forward
![]() Gary has a point also with AutoX Daniel, need to come out for some fun next season, I am one to talk hey ![]() |
I very much appreciate your guys help. The pressure plate and throwout bearing got replaced thanks to David and his perfect diagnosis, clutch now works without a hitch (so far). There was a spring that could just fall out and it was missing a couple of fingers. No major hiccups with assembly, except...
We can't get the dogbone back in. Looks like the engine is too far towards the nose of the car by about half an inch. Suggestions? Here's a photo of exactly what went wrong with the pressure plate: ![]() |
That their is some pretty nasty stuff their.
What are good hours for you, I can stop by and help with the dogbone. Easiest way in my books is to put the car in gear with the engine off and rock it back and forth till the dogbone lines up. Second option is to fire the car up and with the E-Brake on and wheels chocked up, gently let up on the clutch in 1st gear or reverse (depending on which way you need the dogbone to move. The engine will load up the mounts and push the dogbone into place so you can start a bolt into it. This all takes 2 people. I say GENTLY with the club as it won't take much to get the engine to move over. Everyone is super glad to hear you got it running, you will have to bring it by to drop off the tools. I have a ton more books if you want to read through them. David |
The best time would be as soon as is not inconvenient for you. I was hoping to get though Aircare and insurance tomorrow (I work on Thurs), so if possible, before 2pm would be great. If not, come by any time. Perhaps I can get Aircare done early Thursday morning.I'm eager to come to the next club meeting. It's unfortunate that I wasn't able to attend the last one as we were toiling away on the Fiero, but hopefully the car and I will be meeting everybody soon.
EDIT:We got it in! I'll swing by a little bit later to drop off your tools. Edited by Daniel |
It was good seeing you today, the car looks excellent and drives like a new car. (looks like one too) |
Be happy when Aircare is over with...congrats on getting the car running:)
