Diagram for Arctic |
![]() ![]() ![]() ![]() Posted: 18 March 2013 at 8:08pm |
![]() Don't know if you want to explain what is going on whith your ride. Someone may have more ideas. Chay |
Bin working on the beast! an still have a Problm? #First was Red hot real quick exhaust. then as it got hot the ECM would drop the idle an things would be good @ idle. rev it up to 3000 or 4000 an things would get real hot real quick,like melt down hot. so long story short ive checked everything 10x over. Cat was clear when i checked it,took it off an could see right through it,then used the shopvac blower to check the pipes muffler all clear. Fuel--38 to 42lb steddy injectors-bench tested 24 of them an pick the best 6 cold start is all so working Ignition timing set with jumper in @8dg then 12dg to many times to say its bin all over the place. an the harmonic balancer is true an not spun,checked. An no Vac/leeks,eng will stall if choked all so did ether spray an ox from a torch no leeks-tight EGR is new an working,no leeks --know after that and the last putback togather,upper 2x intakes. it starts an runs real nice an dosnt get hot @ idle an seams to be on time an tune.New o2 sensor to. SO heres the mud! @3000/4000+ only the rear 3 CYL-2/4/6 get hot know/red hot-HUMMMMM? this is odd,looks like ELE,bad ground not sure yet. still searching,i will find/fix it! Thanks |
