  New Posts New Posts RSS Feed - Energy Suspension Cheap or just defective
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Topic: Energy Suspension Cheap or just defective
    Posted: 21 February 2007 at 10:21pm
So for the last while I have noticed my 4.9 moving around more than it should, it got so bad that under hard acceleration the alternator Polly would slam back into the strut tower and throw a nice spark show out the passenger side deck vent.  It really sucked.   Today I found out why?
I can't believe it, it is not even the poly that let go, it was the cheap pot metal they used in the shank inside the mount.  It tore right apart.   Is Energy Suspension really this crappy.  I am going to send them these pics and ask them how in the heck this part failed.
It is the 4.9 mount that is on the firewall side below the starter.   The force is pretty much straight up at the location of the snap.
I decided I to make my own style of mount. Thanks to a suggestion from Clynt, I drilled out the center of the mount, went and bought a large stainless bolt. (guy said it was = to a grade 18 bolt )  :D
Ran a large bolt through the center.  Drilled a 3/4" hole in the mount bracket and ran the bolt through that as well.  So now the mount when at rest or decel is sitting on the cushion of the poly, but under load, the bolt locks it like a solid mount.  I am sorry I did not take pics after it was done, but I was too eager to get it installed on the car and take it for a test drive.
The test drive went great, it is solid as a rock and I don't think I will ever have to replace that again.  The brackets that the mount goes into is 1/4 plate steel.
