  New Posts New Posts RSS Feed - Harmonic Balancer Replacement
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Topic: Harmonic Balancer Replacement
    Posted: 29 June 2010 at 9:43pm
Hi all,
I was over at John's tonight to search out a oil leak, can get on the track leaking...and John noticed my harmonic balancer is hooped.
On LORDCO, out of stock, I will call them tomorrow.  So searching on Pennock's as I have no idea what I am doing...and find this site, anyone heard of them?, should I consider the high performance?.
http://www.damperdoctor.com/Merchant2/merchant.mvc?Screen=SF NT&Store_Code=DD
Any input would be great, I need to find and order the part first
Thank you...Brian
Matt View Drop Down
Post Options Post Options   Quote Matt Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:14pm
Have you looked into how you're going to switch it with a new one? I know with some engines it's probably easier just to do an engine swap. Or at least pulling the engine. Not sure about the 2.8L though.
On another note. How did he notice it was hooped? Your harmonic dampener is practically speaking a timing related object. My understanding is that it essentially holds the timing to be consistent during the variables of a moving, torquing engine. More technically it dispensates the resonance of the crankshaft.
If your harmonic dampener is "hooped" you very well may have some crankshaft damage. :(
I wanna go fast.
Fire451 View Drop Down
Post Options Post Options   Quote Fire451 Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:31pm
though.On another note. How did he notice it was hooped? Your
dispensates the resonance of the crankshaft. If your harmonic
damage. :(
Wow that hurt my head....
Brian how is it hooped? Did it just slip or???
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:49pm
If the balancer has slipped on the ring, it is just popped off with a standard puller, personally I use my steering wheel puller.  I can change one out start to finish in about an hour.  The hardest part is you need an impact gun to get the crank bolt off.    Brian if you get really stuck, I do still have my 2nd spare V6 at the house, have not moved it down to storage yet. We can pop it off and pop it onto your car.
On a PS note, most engine guys will tell you this is not possible, but I ran my 2.8 for at least 2 years without the balancer on the engine at all.  It had spun on the doughnut and was wobbling around.  Engine did not run rough or anything.  Kinda made setting the timing a bit of a bear not having timing marks through.
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 10:49pm
The harmonic balancer is relatively easy to change on the 2.8 with the engine just where it is. Removal of the wheel well "skirt" and possibly of the wheel well tub is all that's required for access to the balancer. (Obviously the passenger side rear wheel has to come off as well.)
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 11:05pm
damage. :(
That makes 2 of us.  Hence my post explaining why.
Matt View Drop Down
Post Options Post Options   Quote Matt Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 11:14pm
Np, glad my advice is appreciated.
I wanna go fast.
Post Options Post Options   Quote Capt Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2010 at 11:22pm
Matt really didn't mean to offend and took special note not to attach you I just wanted to get the correct information out.
However if the "head hurt" joke was taken out of context, it wasn't mean to, just a friendly poke.
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 6:22am
A portion of the rubber ring has oozed out at one point, and is missing at another!  It's also wobbling (I was laying under the car with it running and noticed).
I've got Brian heading in the right direction to get a new one.  They're not that much, and it's just as much work to put a used 25yr old one in, as a new one.
It's not like this one is falling off tomorrow - it's just a slight wobble.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 6:30am
Ok "hooped" may have been too much:)...I did get a reply from the Dampner Doctor:
Rebuilt harmonic balancer is all I do. they are stock parts with new silicone rubber. have done them for Corvairs since 1975. works awesome and i used to auto x myself.
cost to rebuild is $69.95 if want one sent out core deposit is $35.00 more toll free 877-834-2137
still going to call around local, then figure out the next steps
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 9:20am
Suggestions please:)...
Lordco 4-8 weeks as they are back ordered / NAPA cannot find the part listing / Dapner Doctor for a rebuilt at a good price...leaning towards the rebuild...
Post Options Post Options   Quote Dr.Fiero Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 9:48am
Since it's not a 'gotta do it tomorrow' situation - weigh the option of cost @ Lordco vs the shipping factor with the rebuild guy.
You're welcome to the one I showed you yesterday to send off to him as the 'core' (which also brings up the 2X shipping cost factor).
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 10:01am
With the core of $35, and Lordco at $135 CAD anyways, paying $100 USD and have it here next week seems to be the best route...I am hoping to get this done before July 9th potential track day, then July 18th Team enduro...if Lordco does not get it here for 6 weeks, my car is off the road by then...lol
Post Options Post Options   Quote Patrick Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 10:36am
Here's a picture of my GT when I was swapping out the harmonic balancer on it.
And a good thread from Pennock's with more helpful info and pictures is Here.
Take note of the comments in that thread about the problem of getting new harmonic balancers with incorrect timing marks.
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 11:51am
Thinking the rebuilt is the choice...I read that post last night, think I'll place my order tomorrow...thanks Patrick
Post Options Post Options   Quote Romeo Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 12:12pm
I'm interested to see what it means by high-performance HB. Perhaps it means that variable-vicsousity ones, but those arn't really performance-orientated, just more reliable. Maybe he means a smaller diametre or some such thing?
Post Options Post Options   Quote Bassman Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2010 at 12:34pm
Only does rebuilt for our cars...
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2010 at 9:21pm
harmonic balancer,i allso need some advise on just what i should do?i have 2 harmonic balancer,the one on the left is off the iron head 2.8 in my Fiero,ENG is dead just as
DR Fiero said it would be! crank is junk! so i got this ALUM head 2.8 to build up with all the good/parts from the 3 -2.8 iron head ENGs i have,all 3 have the same prob!
Crank?any how the crank in the ALUM head 2.8 is deffernt, a big round disk of thick steel in the center with notches in it for crank timeing,so what i would like to know is
can i put the harmonic balancer on the left on to that crank of the ALUM head 2.8, an will it work ok maby? i have looked an iam sure its bin done,some say you can an
some say you can't,has anyone tried this?
Post Options Post Options   Quote ARTIC-1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2010 at 9:23pm
ALUM head 2.8,what year is this motor?
